Securing a Helmet
Securing a Helmet
It was easy to secure my helmet on the RS: pop off the rear seat, loop a short, plastic-covered wire cable around the chin bar, secure to the built-in hook, put seat back. The helmet sat on the top of the saddlebag.
The R is more challenging. The seat's fussier to R&R (and seems like the lock cylinder's down in a tunnel), and there's no hook. Even if there were, I'm not sure there's clearance between the seat and the bodywork to pass a cable. I'm not enamored of another lock, whether clamped to a frame rail or sitting behind the license plate.
Any other solutions? Do the saddlebags (I should get them next week) hold a full-face helmet?
David Brick
Santa Cruz CA
Santa Cruz CA
Caol
- Double Lifer
Re: Securing a Helmet
I don't use a hook/loop either, with the R12R, however, the saddle bags will swallow a full face helmet, no problem.
Kyle
Kyle
#574
#574
Yes, as we all will tell you, both the cases will swallow a helmet. For the times I am without case, I installed a standard helmet lock, about $20, on the frame on the right side. And there are several products that incorporate one or even two locks into a license plate holder. The R is not as convenient in this regard as my last bike either, but it's a really minor consideration.
Mike in SB
2009 R1200R all black
ex1970 BMW R60/5
ex1959 BMW pre-slash R60
ex Matchless G80CS
ex1970 BMW R60/5
ex Matchless G80CS
I've been using a Helmet Guardian for about 2 years now. It works well.
2008 R1200R, Black
+1 on the Helmet Guardian. Here's a link: http://ascycles.com/detail.aspx?ID=1621boxerpaul wrote:I've been using a Helmet Guardian for about 2 years now. It works well.
Makes me a popular guy when I ride with friends ... apparently helmet locks are getting rarer.
Good roads,
- Lewellen
eduardobelmonte
I use a U lock and a plastic covered cable.
I put the U lock embracing the chin bar of the helmet and I pass the cable through any bar of the bike's frame making a loop returning to the U lock.
Then I close the U lock.
I have a back rest, so I position the helmet on top of it, so it's secure and safe from falling down.
The U lock I use is one of those used for securing bicycles.
Of course it's not that strong and resistant, but it works fine.
If I were using it to secure the bike, a stronger one would be needed.
I mean I use it when leaving the bike at daylight in a parking lot or similar situation.
When not in use I pass the U lock through the spiral formed by the cable, and then close it and store in the side bags.
This U lock is big enough so it can secure two helmets at the same time, which I do all the time.
I went to Home Depot ... the motorcycle section... and got a 24 inch (12 inches would have been better) length of cable with a plastic cover ... crimped a loop in both ends. I loop the cable under the handlebars between the risers through the full face helmet...I use an inexpensive lock for the looped ends.
Total .. $6.00 with crimps...
However a setup like this only protects against an opportunist thief. Probably if I had a $1000.00 helmet... with electronics and stuff... I would have a better setup. Mine costs $200.00 and after 18 months ... smells a little.
a Bell Apex
A big plus is keeping the helmet outside while I'm inside (movies ... restaurants )... because coming out of the AC into the humidity usually fogs my glasses and would the visor.
Good you're getting the bags.
Robert
Robert
08' R1200R
Sweet...
Sweet...
rockbottom
I use one of these, when my side cases are full:
http://www.bikebone.com/page/BBSC/PROD/ONGUARD/53-5063
It won't deter the professional thief, but adds a degree of protection against the mischievous, while you are in a restaurant for lunch, etc.
2009 R1200R Alpine White
# 819
# 819
Pacsafe Lidsafe. Works great, protective and very secure. Also makes a great helmet bag for travel.
http://www.pacsafe.com/www/index.php?_r ... tail&id=27
MSF #127350 NAUI #36288
2011 RT
2011 RT
Thanks for all the suggestions. You've expanded my horizons.
You are so right!ka5ysy wrote:WARNING: TEST RIDING THE R1200R IS HAZARDOUS TO YOUR FINANCES
David Brick
Santa Cruz CA
Santa Cruz CA
