Critical Brake Failure abs/servo maybe?
Basmaf
Post by Basmaf »
Hi Guys
I hope you can help with this one. She is an 1150R 04 with ABS and servo assisted brakes.
I have just returned early from my camping holiday due to residual braking issues. :-k
It stated with the brake failure indicator light would start flashing faster than normal after the self diagnostic was complete and the general warning light would go out.
This only happened in the mornings of the last few days but would then be fine when she had warmed up after doing a few miles.
She then started doing it after she had cooled down a bit during the day before I set off again. 8-[ 8-[
This morning the brake failure light was working overtime and would not go out and I was left with residual braking when I was 300 miles away from home. :shock:
I can tell you, you really plan ahead and curse those sods who jump junctions, tow trailers and drive lorrys. :x
I slowly limped to an open garage, I did set off at 08:30 and it is a Sunday, and just as it came in sight the brake failure light went off and the brakes were fine. :o
I decide to cut the holiday short and get home whilst the weather was good and I had full use of the brakes.
On the way home the brakes worked fine, abs and servo no probs, no real issues at all.
The residual braking lessened as well, when stopping for fuel and food.
The pads are fine as I checked and cleaned them3 months ago.
The brake fluids are within the set limits front and rear
She was dealer serviced at 24K March 09 and she is now just showing 500 under 30K
The brake a clutch fluids are due to be changed next March
I was as if the fluid levels were juts a bit low, then when everything warmed up and expanded everything came back within tolerance and all was ok? :?
When I put her away at home, I just checked if she would pass the self diagnostic ok? She did and everything was flashing fine, but that was after a 300 mile run
This problem started on Friday
Any advice as where to start would be gratefully accepted.
-Basmaf
04 1150R In Yellow. On the 7th day God rested, in Yorkshire, and saw it was good.
owldaddy
Re: Critical Brake Failure abs/servo maybe?
Post by owldaddy »
The ABS is very sensitive to voltage. I had a similar problem before changing the battery. New battery fixed my problem. If your 04 has the original battery, it may be coming to the end of its life. Could be that simple.
Basmaf
Post by Basmaf »
Hi Owldaddy
Thanks for the reply
I had the battery issues listed on this forum so replaced the original one with a Odyssey battery PC680.
I have also just turned the ignition on.
She passes all the tests fine and flashing at 1Hz as normal.
Now I am confused.
Will check again in the morning
-Basmaf
Airman
Post by Airman »
Basmaf wrote:Hi Owldaddy
Now I am confused.
-Basmaf
I had a total brake servo failure one time at work. Tried restarting several times, but had no success. I rode home with the scary residual brakes and put the battery on the charger. It worked fine the next day and I've never had a re-occurrence. Low voltage I think.
Basmaf
Post by Basmaf »
Hi Airman
I have just gone turned the ignition on.
She passed all the tests fine and was flashing at 1Hz as normal.
The only difference is she is now in my garage and not in a field
Now I am even more confused.
My normal procedure was start her up, then connect my Garmin, then connect my phone charger,
It was not done the other way round.
Plus the first real time I thought I was going to have to phone Carol Nash, Saturday, I had done 150 miles the day before.
I am going to take the tank off today and check fluid levels. electrical connections etc today to see what I can find.
-Basmaf
