Now I have your attention What is the current rating of the standard horn circuit?
If I want to fit, say a Stebel Nautilus Compact, would I need to wire in a separate relay?
I probably would anyway as I don't want to risk damaging the loom.
Ol' Jeffers wrote:Now I have your attention What is the current rating of the standard horn circuit?
One of my half-done projects is the Stubel horn install. I have a AP-2 fuse panel in place and have run the wires, but haven't hooked it all up yet. I think the common opinion here is to use #16 wire for the power triggered by the relay. I think I used #14, but I'm an extremest. The horn wires look like #22 or something, way too small to power the Stubel compressor, I don't think you'd harm the wiring, but the horn fuse would blow pretty quick I think.
The good news for the project is that I bought a car to drive to work, so the bike doesn't have to be available 365 days a year. Maybe I can get it finished now.
Good luck with it, that horn is an SUV killer.
The horn fuse is the 4th from the left which I believe is good for 14 or 15 amps (it also supplies the Aux. receptacle down by your left foot if you've got one).
The Stebel Nautilus draws 18 amps and comes with a 30 amp relay that you should use...
OK! Thanks guys! Relay it is then! Plenty of room under the seat to tuck that away.
@Airman: Just as a matter of interest, where did you mount your Nautilus?
Ol' Jeffers wrote:OK! Thanks guys! Relay it is then! Plenty of room under the seat to tuck that away.
I used the stock mount in the original location. If you don't have the ABS module it will fit nicely in there as well. I didn't have that option.
