ABS problems
wells01
ABS problems
Post by wells01 »
Hi
I have a 99 R1100R.
The ABS light are flashing alternately. I used an LED and resistor to get the code out of the ABS ECU which pointed to a bad rear wheel sensor which I replaced.
However I cannot reset the Abs system with the switch and I cannot turn off the ABS with the switch.
Is it possible I might have a faulty switch?
Many thanks
omg1010
Re: ABS problems
Post by omg1010 »
wells01
Re: ABS problems
Post by wells01 »
Many thanks for the reply. I disovered the problem was a break in the lead between the ABS switch and the plug.
masu.sk
Re: ABS problems
Post by masu.sk »
I have the same problem on my 98 R1100R.
I read somewhere that after battery replacement by Odyssey PC680 this was solved. These batteries are not cheap (approx. 120 USD), but seem to be really good.
Martin
