Where do you hide your extra key?
duckdave
Donating Member #: 580
Post by duckdave »
In my preparations for a trip, I finally got an extra key made for my RR. I've only had one key for the past year or so; I love living dangerously. Now I have 2 extras. ON Magazine this month (July 2009) suggests hiding a spare, duck-taped to the back of the license plate, which is attached using "spring-loaded wing nuts" so it can be removed without tools. My locksmith friend suggested cutting the top part of the key off (to make is smaller), and keeping the spare in my wallet.
I have no idea what "spring loaded wing nuts" are; will pay a visit to my local hardware store soon.
Concerns: Do I really want my license plate removable without tools? Will the duck-tape get hot and slip, causing the key to fall off? I think if I'm unfortunate enough to lose my key, I might also "lose" my wallet...
So my question for cosmic RR-group input is: Where do YOU hide your extra key?
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
iowabeakster
Re: Where do you hide your extra key?
Post by iowabeakster »
My license plate is held on by plastic nuts and bolts. These plastic nuts are removable by hand. This seems like a smarter hiding place than the one I chose.
(I keep a key duct taped to the underside of the frame under the steering head. But, I won't give the exact location on the internet.)
I also keep another one in the tank bag if a potential thief can't find the duct taped one.
This is a wing nut. Spring loaded just means that there is a springed locking washer used to keep it from spinning off from vibrations.
CRazyCam
Post by CRazyCam »
Hi duckdave... with a user name like that, I guess you have to use duck-tape someplace!
I use a key clip, hooked onto my belt, for all my house keys, and, in amongst those, I have a spare key for my BMW.
It's one of the "spare" keys without the BMW logo or anything to give it away.
That way, I go for a ride on the bimmer, grab the BMW key (normal one) with the BMW tag, and I still have a spare on me.
It's also handy if I decide to go out on one of the other bikes, since my wet weather gear is normally stored in one of the BMW panniers, so I grab the Triumph key, but, once in the garage, can still open the BM panniers.
regards,CrazyCam
Boxer
Donating Member #: 2
Post by Boxer »
You don't need a spare key. Just leave your key in the ignition all the time. I've done it (except at motel room stays) for over 6 years and all over this country and Canada, and never once did my bike get stolen. If you're not comfy with that concept, get one of those BMW roundel key heads and attach it to a "sawn-off" key top. That's what we describe in black ops as a "stealth key". :^o
mcollect
Post by mcollect »
Hide it in plain sight.I also just leave my key in the ignition attached to the BMW roundel. But I also have a spare inside my Big Mac tank bag
taped to the patten.
Michael
MG 78 LeMans
2002 R1150R
78 R100S
wncbmw
Post by wncbmw »
I do a version of the 'hide in plain sight', with this setup I bought at a BMW shop. Forgot who makes it. I have had service techs ask me for the key with it in the ignition! :lol:
A backup is in the tankbag in a ziplock with the anonymous book, insurance card, etc.
Vann - Lifer No. 295
scottybooj
Post by scottybooj »
I would like to set up a way to have the key turned on and use a battery switch under the oil cooler somewhere. Kind of like what we had set up in our boats.
That way I could get a set up like Vann and just turn a knob that's hidden. SHABANG!
Scott
Black '50R
Long Island, NY
challey
Donating Member #: 365
Post by challey »
There is always this solution:
"The Grifter is a handy box that fits underneath your license plate and provides a locked storage box for documents, valuables, small tools, and so forth. The Grifter includes two keys, and fits virtually any motorcycle." http://www.cyclegadgets.com/Products/pr ... em=GRIFTER
Of course, since you need a key to open it, you really haven't gained a whole lot . . .
Charlie
'03 R1150R
Life member 365
Errabundi Saepe, Semper Certi
lionlady
Post by lionlady »
I've got a spare sidecase key (bought the cases used) inside a turn signal lens. Other than that, I've got one of those Roundel keys that simply stays in the ignition.
P
ATGATT: Because it's better to walk away in disgust than ride away in an ambulance.
duckdave
Post by duckdave »
I'm thinking of all the panic I could instill if I started plucking up ignition keys from motorcycles (stealth or not). Fortunately, I just not that type of guy... but it might be fun for a laugh or two. :badgrin:
So I guess the reason I don't leave my key in the ignition (except when I forget) is I'm afraid someone would liberate it. Up until last week, that would put me up the preverbal creek, without a paddle, no less. Actually, I would still be in a pretty good bind since my spare key is currently sitting on my dresser at home. #-o
Taping a spare to the back of the plate is sounding pretty good. If I could not remove the plate without tools, I could probably just bend it up a bit. I also like the idea of the turn signal hidey-hole, except that still requires a tool for access, or the use of some destructive forces.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
Marty2
Donating Member #: 492
Post by Marty2 »
On the same chain as one of my old Dog Tags, worn around my neck.
# 492
2013 Wee Strom
There is a thin line between "hobby" and "mental illness"
combustor777
Post by combustor777 »
In my pocket...?
lionlady
Post by lionlady »
duckdave wrote:. . . I also like the idea of the turn signal hidey-hole, except that still requires a tool for access, or the use of some destructive forces.
I've got a phillips head screwdriver in my tailbag. ;) If you carry a Leatherman tool, you'd be "covered."
P
Basmaf
Post by Basmaf »
I keep my spare stiched into the label of my jacket, just in case.
Basmaf
04 1150R In Yellow. On the 7th day God rested, in Yorkshire, and saw it was good.
Boxer
Post by Boxer »
My extra key always rested in the side case lock where it was easy to unlock the bag.
frozennorth
Donating Member #: 506
Post by frozennorth »
Inside pocket of my jacket. After a crash a few years back, I never ride without body armor, so always have a spare that way :)
Red 02, R1150R
Member # 506
I am an empty hospital!
WildBlue
Post by WildBlue »
frozennorth wrote:Inside pocket of my jacket, I never ride without body armor, so always have a spare that way :)
Ditto
Chris
2002 BMW R 1150R ABS, Black, 27,000+
Life is a Game. Play to win.
NoRRmad
Donating Member #: 388
Post by NoRRmad »
Ditto.
duckdave
Post by duckdave »
I decided against keeping the key in gods plain view---if swiping a key would cross my mind, no telling what others might do.
I decided against keeping the key in the turn signal---I actually took mine apart to see if it would work for me---decided the possibility of shorting was not good.
I decided against keeping my key taped to the license plate (well, that one is slightly still in consideration)---'fraid it might fall off (100+°F weather here this week).
I decided (drumroll) to hide my key in my boot, in the cool little hidey-hole thing ("Greg Frazier Stash Pocket) I got from Aerostitch. We will see how that goes. Or maybe I'll just stick an extra set in my side case that doesn't lock...I usually have them around, except when they fall off.
Thanks, all.
-d.
-duckdave
'04 R1150R Silver
Little Rock 'n Roll
Double Lifer #580
bubbac45
Post by bubbac45 »
Under the foot rest rubber
and in my wallet (the flat spare key from BMW)
and at the dealer in a ups mailer envelope
Chris
