The two different plug brands are standard for the bike:
12127653771 - spark plug (BKR7EKC M14)...NGK
12127681415 - spark plug (YR6LDE M12)...Bosch
I'll look into the Autolites the next time around but I already had replacement NGK and Bosch plugs for this service.
Re: preemptive coil replacement...it seems to be an established problem and would just be one less thing to consider when I'm on the road, carrying a spare doesn't sound like the worst idea ever but how many spares can you really carry on a bike before it becomes absurd? Did I really just ask that question?
The consensus seems to be a standard "they all do that" which I am more than comfortable with and pretty much what I was hoping to get. I'd never replaced plugs on this bike myself and I was just looking for a baseline.
boxermania wrote:Leaving the details aside.......
The primary plugs look good.....that is the way (color) the porcelain should look. Although, for a real read you have to look down into the plug.
The secondary plugs look like they have endured significant heat.....the porcelain is brownish and all the threads are of the same color. Normally three or four threads will show any semblance of color, like the primary plugs.
Last but not least, seeing two diferent plug brands lends credence to your suspicion that the secondaries might not have been changed.....they also show a bit more wear at the center electrode.
Personally, I would go with the Autolites 3923P, single electrode for the primaries at .030" to.032" gap and a comparable for the secondaries but one heat range colder(so it transfers more heat to the surroundings)
Good luck and let us know the outcome.
