Cool air around throttle body
gel9001
Post by gel9001 »
Hi,
Lately, when the engine on My 2004 R with 40K miles is warm/hot, the idle drops and engine runs rough. I put my hand near/around the left hand throttle tube and I feel cool air circulating around it. If I do this to the right throttle tube I don't feel that same cool air.
Is this a vacum leak? anyway to further troubleshoot
thanks,
Gene
TicTac50
Donating Member #: 586
Re: Cool air around throttle body
Post by TicTac50 »
Find a cigarette smoker and let him blow a puff on the left hand throttle tube.
At lest you will see where the vacuum leak is.
I think there is an O ring there that needs to be replaced.
Or just lube it and re tighten it.
Good Luck.
Lifetime Member #586
2002 R1150R
2004 R1150 ABS
2003 F650 CSA
PRESSING "1" FOR ENGLISH!
iowabeakster
Post by iowabeakster »
I am totally baffled about the cool air around a warm engine. (EDITED) Maybe it has to do with the intake snorkel there on the left side.
But for the:
I will take a guess...bad coils. You will find the testing technique in the threads below.
Here's one...
viewtopic.php?f=2&t=17626&start=0&hilit=testing+coils
another...
viewtopic.php?f=2&t=17797&start=0&hilit=coils
and third times a charm...
viewtopic.php?f=2&t=17635&start=0&hilit=coils
