From what I've heard from dealer service departments and read about everywhere else, the R1150 OilHeads do not require any clutch spline greasing servicing. Older AirHead BMW's did have that requirement, so that's why it spilled over to the newer models.
One problem though . . . . those "no maintenance" splines are failing at much too high a rate, considering similar designs in other vehicles THAT
NEVER EVER FAIL !!!
Most prone to fail are the R1150RT models that routinely experience high cruising speeds and carry heavy loads. The reason for failure, obvious to anyone that notices the spline's partial axial engagement and has seen the failed parts, is poor design and very likely improper materials in the clutch hub.
Because of expensive components that can be damaged, like the swingarm pivot bolt threads in the rear transmission case, this is not a job for those of limited experience and basic tools. Considering spline failures have occurred with as little as 11,000 miles, choosing a good time to take yours apart for inspection and greasing doesn't seem possible. A good number might be 25K or 30K miles. Even with my 2002 model's odometer reading 61,877 miles (99,581 km) I initially dreaded the thought of having to take so much of the bike apart (the 1st time), but once the parts started accumulating on the floor and in my pickup's bed, it was almost therapeutic. I was impressed with what can only be described as sophisticated engineering, yet troubled why such brilliance and visually premium quality parts have so many troubling, very costly failures. There was a anxious moment leading up to pulling the transmission out for my 1st look at what could be a very costly R&R if the splines were worn. It turned out better than I thought but my plans to trade it in for a new F800ST still went forward. While "in there" I cleaned out the throttle junction box, found out my clutch slave was destroyed and added a TransOil/DOT4 drain fitting and line to the clutch slave housing.
Here's the album:
http://s142.photobucket.com/albums/r87/ ... plineLube/
