Finale Drive and Swingarm repair
R601968
Post by R601968 »
Can anyone tell me the correct size for the tools needed to remove the pin in the swingarm and the locking nut on the pin?
The Velvet Monkey
Re: Finale Drive and Swingarm repair
Post by The Velvet Monkey »
For the pivot pins you need the following:
1. a heat gun or propane/MAP torch to heat the pins to break the Locktite 270;
2. a 30mm socket for the locknut on the inboard pivot pin;
3. a 12mm hex socket (I went online and got one a Tooltopia for (I think) $12.00).
2004 50R a.k.a. "Hiedi"
No!!! Bad monkey!!
There's a lot of important details you need to know, all covered in great detail here:
http://r1150r.org/board/viewtopic.php?f=2&t=16784
Read the entire session to get all you need.
R601968
Post by R601968 »
Thank you for the knowledge and information. I doubt the swingarm bearings are bad, will proably find a need to replace the finale drive bearing
