license.plate
dd
license.plate
Post by dd »
hi.
i was trying to install my license plate on an '07 r1200r using all four bolt holes.
i am having a very difficult time doing this.
if you have tried this, i imagine you ran into the same lack of space issue.
does anyone have a good solution?
-daniel.
it seemed like a good idea at the time
Tak
Re: license.plate
Post by Tak »
I cut an aluminum sheet (1/16" thick) slightly larger than the license plate and drilled 4 holes in it to match the mounting holes on the bike. Then I drilled another 4 holes to match the license plate. Painted it black. Mounted aluminum plate to bike then mounted license plate to the aluminum plate.
dd
Re: license.plate
Post by dd »
tak,
hi.
thanks for your reply.
i don't understand how your solution fixes the problem i encountered.
i found that there was not enough space on the inside of the license plate frame to fit a wrench to tighten the nut for the 'top' bolts.
how did you get around this?
-daniel.
motoracer8
Re: license.plate
Post by motoracer8 »
I belive I used 5X20 screws, could have been 5X25. They are the same black torx macine screws BMW uses in other places. Nuts for the top two screws are alittle difficult to get to, I used a pair of needle nosed pliers to hold the nuts in place while turning the screws.
Ken G.
xprof
Donating Member #: 617
Re: license.plate
Post by xprof »
I'm both ham-handed and impulsive, so I used my Dremel tool with a cutoff wheel to cut away the plastic that was in my way. Then I cut off the red reflectors, which I never liked and which you won't see on European bikes. I have had no regrets about it, but this may be a bit radical for you...
Mike in SB
2009 R1200R all black
ex1970 BMW R60/5
ex1959 BMW pre-slash R60
ex Matchless G80CS
thepeacebullgrunt
Donating Member #: 952
Re: license.plate
Post by thepeacebullgrunt »
Ah ah ! :lol: Its Funny dd !
I had the same issue 2 weeks ago with my dealer mechanic helper... I was watching him working super fast, not selecting the right screw lenght, forgeting the loctite and as usual at the end asking me quickly without any form of shame "Is that right for you that way ?" waiting for my answer to seal the deal while hiding with his hand the two upper area screws holes that he decided to simply leave empty !
A bit pissed off I told him what disturbed me in the result of his work process.
And him too bit upset he had to re-do the whole job with medium loctite, proper length screw and spend 10 minutes more with the right tool to block the bolt behind the mounting while screwing carefully on the other side...
Et Voila ! =D>
Pain is Ignorance this is why it really hurt...
NeilS
Re: license.plate
Post by NeilS »
I've replaced the machine screws with stainless steel sheet metal screws. They very nicely cut threads into the plastic license plate bracket, so I don't have to worry about the nuts at all.
mogu83
Re: license.plate
Post by mogu83 »
Basically same as above. I ran a tap through the hole (5mm I think) and bought four SS socket head bolts with washers and ran them in till they were snug. Two years and 20+K and everything is still tight. Looks neat and it's easy.
Add a $6 license plate surround and it cleans up the plate area a little.
Phillo
Re: license.plate
Post by Phillo »
This is strange, my number plate tailpiece only has three holes and I mounted the plate using stainless steel machine screws & nylock nuts as per the pics.Image Image
R50/R69S/R50S/R65LS/XT660R-2007 R1200R- Now 2009 R1200GS - 69 YEARS YOUNG STILL GOING STRONG
Re: license.plate
Post by deilenberger »
One word: "nutdriver" (metric of course..) Harbor Freight has a cheap set that is fine for stuff like this (nutdrivers normally aren't used for high-torque applications..)
Tak
Re: license.plate
Post by Tak »
Daniel,
I used an open end wrench held at an angle such that only the tips made contact with the flats on the nut. I used self locking nuts so I did not need to apply much torque, just get them snug.
Tak
