R1150R brake pads-best choice?
I'm ready for some brake pads-I don't want HH pads but looking for advice from your experience.
Re: R1150R brake pads-best choice?
EBC .... nothing else for me.
Cheers
Cheers
they make several types-which have you used???
- The Velvet Monkey
Put Carbone Lorraine on the back (sintered). They perform real well, were reasonably priced, but look like they're wearing a little faster than the OEM versions. Well, I should say the inboard pad is wearing faster.
Next time, I'm going to give EBC a go.
2004 50R a.k.a. "Hiedi"
No!!! Bad monkey!!
No!!! Bad monkey!!
I'm on my second set of EBC rear pads, the organinc, not the HH. They last about 14k between changes. The front pads at 30k have never needed replacement. I believe the fronts are sintered. I have heard the front discs are harder than the rear disc and that would seem to be true. I never use the foot brake except when puttering through filling stations. The way I have hammered the brakes on occasion, I supect the organics wouldn't last long on the front. Have you noticed any wear on the rear disc using the sintered pads ?The Velvet Monkey wrote:Put Carbone Lorraine on the back (sintered). They perform real well, were reasonably priced, but look like they're wearing a little faster than the OEM versions. Well, I should say the inboard pad is wearing faster.
FA294HH, outstanding stopping power. Just changed my rear to a Brakin' Disc. Why not HH, if I may ask?kantuckid wrote:they make several types-which have you used???
My understanding of HH is that they are better when used in a racing application under repeated high temperature braking. Correct me if I'm wrong.
I only use HH because they are touted as better stopping power, it is a safety thing for me. I would use the non-HH if it is just as effective. Any adverse effect of using HH? See, it is an education for me
I'm learning. Go to www.dp-brakes.com for a good commentary on the different kinds they offer, including HH. Also read the history of the company for more about friction materials as used in disc brakes. I am still left wondering if the only compromise with HH vs. regular sintered is life of the pad and rotor? With cars I always made the deduction that a little brake dust was better than a lot of $ for rotors and the same for bikes too. There are also the full out pads mentioned there that obviously have a heat requirement that exceeds normal street use to be more effective.
I posted the same question on the BMWMOA Forum and have had one response that sort of chastized me over a question re: the Chinese pads for sale on eBay -actually it wouldn't surprise me if they were making BMW's pads.
I have run several sets of EBC "organic" or Kevlar rear pads both on an 03 and now on an 04. The term "organic" used to refer to asbestos pads as I understand it. I went to the organic to make life easier on my rotors (and my wallet). They typically lasted from 12K to 16K on the rear. I had no problems with them at all other than the short life span which I am willing to live with in return for longer rotor life (I hope).
wayne
wayne
- The Velvet Monkey
You know, sintered pads do apparently wear the disk out faster, but I sure haven't noticed it and I've checked.Airman wrote:Have you noticed any wear on the rear disc using the sintered pads ?
No!!! Bad monkey!!
No!!! Bad monkey!!
