One small improvement at a time - this one was foam grips
macx
Post by macx »
WONDERFUL addition!
I had read about lubing them up so they'd slide on - I think I read one post about
using WD.
Well, being "somewhat overly detailed" in my reasoning at times, I got to thinking
that WD is actually a penetrant and therefore somewhat like a solvent rather than
an actual lubricant, and didn't want to dissolve my nice new foam sleeves.
So got out the Pam cooking spray - wow, slid right on!
Now for the setbacks.
snowprick
Donating Member #: 3953
Re: One small improvement at a time - this one was foam grips
Post by snowprick »
"Now for the setbacks"
They slid off at the traffic signals and you bit the bar? :cry:
Rod
Apple Macintosh
macx wrote:WONDERFUL addition!
using WD.
BAD idea. :(
the best thing to use is hairspray (oddly enough).
The idea is that whatever you use is a lubricant for a BRIEF period of time, to allow you to slide the grips on, then turns into a GLUE to stick the grips to the metal of the bars.
Cooking spray will be a permanent lubricant - I bet you can still rotate the grips on the bars. :(:(
As said - hairspray (or a very, VERY fine dab of washing up liquid - it dries into a sticky substance) are the ONLY things to use. That said - my normal method (to be honest) is a few drops of spit!
Buckster
Donating Member #: 543
Post by Buckster »
I absolutetly love my foam grips! I wished I would have bought the right size though. I used hot soapy water and that was not enough...had to use a liberal amount of WD which worked. I almost knocked the bike over and about a half hour to get on.
Buy the large size if you get them from Beemerboneyard!
Buckster '03R
#543
Photoguy
Donating Member #: 678
Post by Photoguy »
In the off-road world, Renthal grip glue (acts as a lubricant until it sets up) or hair spray/WD and safety wire is the way to go. I'd be a little concerned about cooking oil spray not fully evaporating leaving the grips free to twist under any force.
macx
Post by macx »
I'm sure those are valid concerns - but I of course had to take a ride the next
day when the mercury finally peeked above 50.
Drove several miles thru towns and about 40+ on various 2 lanes with a number of
stops etc, and of course included a few forays into bursts of speed somewhat over
the legal limit :-)
Nary a problem! No slip at all. Maybe I just used the right brand :-)
I got both of them on in under 5 minutes - only problem at all was the leading
edge of the sleeve rolling under a little when it went over the bar end.
As soon as I saw that was happening, I stopped and "retrieved" it and the
sleeves then went on quite easily. I did think to test them to see if there
was any slip, and even gripping quite firmly I couldn't get either one to slip.
Even cooking oil will eventually dry, and when you consider the amount of surface area
contact between the entire inside of the sleeve and the handgrip, coupled with
the snug fit, well - if you have to turn the throttle hard enuf to make it slip
you maybe need a bigger motor ?
Just for my own curiosity I tried starting one over the bar end without anything
and saw it was going to be nearly impossible without maybe even tearing up
the sleeve.
Just my own experience, not saying it's the best way, just that it worked great for me.
Hairspray for sure. =D>
Used it many times on the dirt bikes. I replaced many grips form the many falls incurred. #-o
you maybe need a bigger motor ?.
More a case of pulling the bike up off the side stand, or from a low speed spill, and the grip coming off the bar - leaving your bike to go back down on the ground with another thump!!
Beaze
Post by Beaze »
Make like a happytime star and spit inside those new grips like you're a Llama. Spit dries up and no slippage, or just use rubber cement, no expansion when it dries and it sticks like hell. I prefer the rubber cement so you don't have to worry about the grips rotating and sliding off the bars...
harrisphil
Post by harrisphil »
just to add my tip
I put the grips on with spraypaint
same idea but not being a girl i dont have hairspray!!! :-)
