At 39months of ownership from new and 31800mi, I've got the 12-6 / 3-9 FD BearingBlues!....
The other day, I felt a distinct buzz in the pegs as I made the hard left turn onto my street. I immediately turned into the church on the corner (ostensibly to pray ?
Yep...there's a buzz alright. More pronounced on left turns than rights, for some reason. The turns must be pretty tight also, or there's nothing there. I think I may have felt this once or twice in the last couple rides, but I cannot say for certain.
Got home and up on the centerstand I torqued the wheel....there's a very slight movement in both planes.
It's there...it's palpable...it's #%%@ annoying!
In the interests of complete accuracy, the 3-9 movement is not there (I think) when the FD is hot, like after a ride. Or like the 10 times or so I checked today during a ~250mi outing. Next day tho, you can def feel it. And I'm pretty sure the 3-9 movement is new (pivot bearings need tightened/replaced?), and that I have always had some 12-6 movement. The 12-6 seems to be a little looser, tho...
But the Buzz is definitely new!
Before I decided to ride it today, I changed the FD oil (Mobil1 75/90). The old stuff, if you can call oil w/ only 3700mi on it 'old', came out perfectly clean....no metal etc, just the usual fine fuzz on the magnet plug. I got a sample for BlackstoneLabs...I'm debating whether to send it.
I also took the tire off, because I had just (1300mi ago) put on new Pilot Road 2. Maybe I did not torque things down right, or maybe the PR2s hum after scuff in? Everything went back on as it should, and no sign of any leaking from anywhere. And even tho I had palpable movement in both planes, they were very, very small....so I decided to saddle up.
Sooo...is this nothing? Or the very beginning of something?
I was thinking of riding into the dealer, and being only 3 months out of warranty, perhaps getting some of this repair covered...
If it is on the way out, how long will the big bearing take to self-destruct anyway, seeing as that I don't stunt, go off-road, and take it easy over RR tracks?
As always, any insight (consolation) is always welcomed....
