After servicing my Rockster and changing the plugs,
tickover was still down (850rpm) and the bike had been running a little rough.
I decided a TB balance was in order.
I constructed a manometer from the excellent guide found on this site.
http://obairlann.net/reaper/motorcycle/manometer.html
Connected it up and let it settle.
This was the initial result at tickover.
A slight turn on one adjuster brought the vacuum into line then I turned both screws
up a little at a time until tickover was at 1000 / 1050rpm.
Opening the throttle slightly to about 2500rpm, brought the following result.
Adjusting the right hand cable length balanced the levels again.
(This is VERY sensitive, about 1/4 turn of the cable adjuster).
Rockster is transformed.
Cheers for the advice on the manometer.
Total cost, £6.00 for the 1/4" tubing from ebay, an old bit of wood and
some old brass wire. Well worth the "expense" and an hour to make / use it.
Ian.
