julia rose wrote:i have a 2002 r1150r and am trying to keep on top of checking the oil. the dealer says it must be on centre stand and flat ground. okay okay i dont like having to put it on centre stand (fear of it falling the other way). i do know the technique and will do this if i have to. i've also tried a mirror against the wall and sitting on the bike upright to check. the reading does vary depending on how straight the bike is so i know how easy it is to be off.
the thing is that i am getting different readings so i want to make sure whatever approach i use is the most accurate.
i check it cold in the morning or an hour after i stop riding. and it should be half level right? i know the min and max levels to watch for.
one more thing i was wondering about, i was only getting 95miles before my yellow low gas light went on. the dealer adjusted the throttle yesterday so i dont know if thats resolved it just yet. hopefully that's the problem fixed but if not, what else might it be.
Julia
Hi, Julia,
Welcome to the forum and all things RR
Oil check: after a thorough warm up
side stand for 5-10 minutes
center stand for 5-10 minutes
oil
anywhere in the sight glass is ok
That is the way to check it--some say 7-10 minutes but 5-15 probably works well enough--just easier to remember 5-10--don't get too anl about the exact times; with time you'll get a feel for it.
Any other method is not as accurate, though many will check cold in am and swear by it. Center stand is crucial, I believe
Re the low fuel light
How many gallons do you take when it first goes on? If you are taking just a couple of gallons, chalk it up to an overly sensitive light. They have been know to be flakey. If it is taking 4 gallons it would be unlikely for a healthy RR to get only 20+ mpg
After the "throttle" was adjusted___was that a "throttle body sync?" was there a noticeable improvement in performance? Freq there is, esp if they were out of adjustment (sync)--what that does, and there will be people that don't like this analogy--is "synchronizes" the fuel delivery to each cylinder--Think of your bike as having two engines--the right and the left. If the delivery of fuel is greater on one side than the other (or out of "synchronization"), power delivery is compromised. Adjusting the fuel mixtures and cable lengths--the throttle body sync--will restore or achieve the balance between the "two engines" so that they are optimally working together, one hand helping the other.
Layman's terms to be sure, but that is how I understand it.
Again welcome
