ONE BIG A** POTHOLE
Eqyn Dad
ONE BIG A** POTHOLE
Post by Eqyn Dad »
It was a great morning to go fast and find the twisty roads...until I found the mother of all potholes and was not able to deviate from my path to avoid it.
The tire did not loose inflation, and I don't notice any high speed vibrations but there is definitely a hit on one side of my rim at the bead which is noticable (visually)with a slow rotation of the tire.
So this is one of those things which just bugs me...can a slight hit on the rim be fixed?
Any suggestions would be appreciated. Thanks.
Re: ONE BIG A** POTHOLE
I'm not aware of any method of repairing a cast rim. Replacement is the only option I know of. A new wheel is expensive. Good luck!
Beemeridian
Donating Member #: 477
Post by Beemeridian »
11
Eqyn Dad
Post by Eqyn Dad »
Thanks for the input. I put an e-mail into the company and I will post my results.
Thanks again.
HikerGlenn
Post by HikerGlenn »
You might try this guy- http://www.framestraight.com He advertises wheel straightening to within a couple thousanths of an inch.
HikerGlenn
Here's another one: http://ourworld.compuserve.com/homepages/WireWheels/ Hope this helps.-Glenn
Ves
Post by Ves »
Talk to the Department of Transportation in the city. See if they will reimburse you for a new wheel... raise a stink... seriously.
