Hi everyone! New to biking here. Just got the R1200R as my first bike. LOVE IT! Yeah, this bike is my new addiction!
Can anyone walk me through how to connect my Zumo 550 to the power on the bike. I'm looking at the bike right now and I have no idea what cords even go to the power. The last thing I want to do is disconnect the wrong cable. Do you think I should just have my dealer install it? Is this something a newbie should even attempt.
I appreciate any advice.
Thanks,
Grant
Grant - which Zumo 550 do you have? If you have the BMW one - it should come with a cable with a connector on the end that plugs right into the wiring harness. The mating connector is tucked up under the tank, right near the front right side mounting point for the tank (left side looking at it from the front.) It may or may not have a tie-wrap holding it to the frame, and it has a plastic cap over the end to protect it that you must remove.
If you have the Garmin version of the 550 - it probably came with a power cable you can connect to either a BMW accessory plug (and plug it into the power outlet on the bike) or to the battery directly.
I connected mine directly to the battery. You can run the wire forward right up next to the tank, right or left side, without having to remove anything so it doesn't show. I'd attach a picture but, well, it doesn't show.
'07 R1200R
Life Member #599
NAUI Inst. #1434 (since 1969)
I took some photos under my seat. Do you know of any websites that would sell the right adapter for my bike? Or do I need to order the Universal Socket Adapter from BMW? They don't have a socket adapter specifically for the R1200R.
For Garmin hookup option "A" go to www.sierrabmw.com and search for "adapter." They offer three choices to go from the BMW socket to a standard cigarette lighter socket. You can then just plug in the Garmin cord with the cigarette lighter plug supplied. I used this adapter to charge my phone while riding (there is no power to the BMW socket when the bike is turned off).
Garmin hookup option "B" is what I used to wire my 550 directly to the battery. Note that the cord already comes with an inline fuse. It is a five minute job.
I attached the GPS itself to the left handlebar with a RAM mount u-bolt (pn# RAM-B-231CHU) (http://www.ram-mount.com) and the hardware supplied by Garmin. I mounted it as far left as I could get it so it doesn't get in the way of my seeing the instruments or my tank bag.
I hope this helps.
'07 R1200R
Life Member #599
