Trickle Charger recommendation
jclanin
Post by jclanin »
Hi all,
I'm a newbie.... proud new owner of an '04 ABS R1150R (thanks Richard!). Love the bike. I'll have lot's of questions for sure.
To start:
What's the best trickle charger for this bike?
I'm getting a slight whining noise when engaging either brake - is this normal for an ABS bike?
that's all for now... thanks,
JC
--I'll post pics soon...
Re: Trickle Charger recommendation
owldaddy
Post by owldaddy »
The whining noise is normal, your hearing the pump move brake fluid around. As far as the battery tender goes, you should have a gel battery in a 2004, so just make sure the battery tender you get is rated for that battery. I bought a BMW (made by Deltran to BMW's specs) tender, I know it is a few bucks more, but I knew I had the right one for the job.
Don
cricman
Post by cricman »
I have used a Battery Doc for the last 3 years, and it has saved me over $100. How do I know? Because I killed the first battery due to infrequent riding habits. Since then, I have had no problems with my second battery. Its small, gel friendly, and came with the correct adapter for the BMW accessory outlet.
cricman
eric
The Battery Tender Jr is a very good charger for the gel BMW battery. Inexpensive as well.
Hawkman
Post by Hawkman »
+1 Battery Tender Jr
~Eric
'03 Silver R1150R
jclanin
Post by jclanin »
cricman wrote:I have used a Battery Doc for the last 3 years, and it has saved me over $100. How do I know? Because I killed the first battery due to infrequent riding habits. Since then, I have had no problems with my second battery. Its small, gel friendly, and came with the correct adapter for the BMW accessory outlet.
cricman
So you just plug the Battery Doc directly into the accessory outlet - you don't have to connect to the battery? I assume you got the Sport Battery Doc?
thanks,
JC
MartinW
Post by MartinW »
have always used an Optimate trickle charger on mine.
still using the originally supplier battery on my '02 R which is now over 6 years old.
Life Member #551
02 Blue BMW R1150R non-ABS
snowprick
Donating Member #: 3953
Post by snowprick »
MartinW wrote:have always used an Optimate trickle charger on mine.
+1
Rod
Apple Macintosh
cricman
Post by cricman »
thanks,
JC
Hey JC, You can plug it into the accessory outlet, or it also has the means to wire a fused pigtail to the battery. I think it is the Battery Doc Sport. I got it from the local (Fort Worth, TX) BMW dealer and paid $39 for mine in 2005. They are about $35 and shipping on ebay. If you go to their website, there is a review from BMW Owners News:
http://www.batterydoc.com/pressh.htm
cricman
eric
jclanin
Post by jclanin »
Thanks for all the recommendations guys! I can tell this will be a great resource as I learn about the bike.
Heading to North GA for a long ride tomorrow - weather permitting... Can't wait!
JC
