Shifter rubber
Aitch
Shifter rubber
Post by Aitch »
The shifter rubber on my R1150R leaves black marks on all of my left toes.
It's not such a big deal on "riding" boots but I use the bike for commuting to work where riding boots aren't quite so appropriate.
Can I replace the black rubber? I've not determined how it is installed or whether it will readily come off.
I suppose I could wrap it with something but I was looking for something a bit more permanent like some vinyl tube.
Any suggestions?
Thanks,
Aitch
02 R1150 R Black
69 GMC Stroker
84 300ZX
74 CL450 Scrambler
Which way where and if any when?
Goff
Re: Shifter rubber
Post by Goff »
There's a couple of tip replacements might work for you, supposed to give better feel and grip on the lever too. Wunderlich do em, I'm sure there's others too...
taosports
Re: Shifter rubber
Post by taosports »
I think the more practical solution is to just leave a pair of shoes at the office or pack them with you. You can replace the shifter rubber, but due to it's location, no matter what you use, it's going to pick up dirt and pass it on to the tops of your shoes.
rdsmith3
Donating Member #: 74
Re: Shifter rubber
Post by rdsmith3 »
taosports wrote:I think the more practical solution is to just leave a pair of shoes at the office or pack them with you. You can replace the shifter rubber, but due to it's location, no matter what you use, it's going to pick up dirt and pass it on to the tops of your shoes.
That's what I do. I want my feet and ankles protected by good boots while riding to work. I have a pair of nicer shoes at work that I change into.
I think that any material on the shifter would eventually make marks on your shoes.
Bob
2002 Atlanta Blue
Lifetime Member #74
Green Hornet
Re: Shifter rubber
Post by Green Hornet »
tRY AND LOOK UP "SHIFTER SKINZ"
Or motorcycle boot protector
I use one and takes care of the problem.
Micky
Micky
2000 Moto Guzzi Jackal
2004 Rockster - Green
Buckster
Donating Member #: 543
Re: Shifter rubber
Post by Buckster »
I have the Wunderlich version and it leaves a silver mark instead of black.
I take my work shoes in my tankbag to work.
I thought about some clear tubing to slide over but have not tried it. My boots are sort of thick and it may make it harder to shift.
Buckster '03R
#543
snowprick
Donating Member #: 3953
Re: Shifter rubber
Post by snowprick »
Wear black shoes :mrgreen:
Rod
Apple Macintosh
def38
Re: Shifter rubber
Post by def38 »
Aitch wrote:The shifter rubber on my R1150R leaves black marks on all of my left toes.
Aitch
All five of them? Just put on some socks!
Aitch
Re: Shifter rubber
Post by Aitch »
All good suggestions. I had not heard of Shifter Skinz, that would work.
Also, the notion of wearing black shoes and socks has merit.
I was really wondering how the shifter rubber is installed. Looks like the toe peg is pressed into the shifter arm?
If I could figure out how to dissasemble, I'd replace the black rubber with clear tube.
Cheers!
02 R1150 R Black
69 GMC Stroker
84 300ZX
74 CL450 Scrambler
abglenn
Re: Shifter rubber
Post by abglenn »
Just drive to Lowe's Electrical Dept. and buy some white heat-shrink tubing and heat it to the black shifter rubber. The down side it may not last forever, buit can be easily replaced.
snowprick
Re: Shifter rubber
Post by snowprick »
Place left foot in a Tesco plastic carrier bag. For added comfort tie string around the ankle, this will keep the rain out. :mrgreen:
Rod
Apple Macintosh
