12v accessory socket
Hi again.
does any body know were my 12v socket is i cant seem to find it, i`ve looked near the left foot peg but can find nothing, do rocksters have the wire coiled up somewhere ? the reason i ask is my battery is low and wish to trickle charge,
any help would be much appreciated,
cheers Gaz
cheers Gaz
- Nakigara
Re: 12v accessory socket
On my Rockster the plug itself was an option. If I remember correctly, the plug itself was around $15 and installs in a hole on your starter cover that has a blank plug that you need to remove. There is a small quick connect to the wire loom behind this cover that the new plug will snap into. I don't know why BMW didn't just put this on the bike in the first place?? Hope this helps!
Dan
Dan
If I am not mistaken the 12 V socket was not factory installed for the European (or at least UK) Rocksters.
If you want to charge your battery - in the short run you can just remove the starter cover (located near THAT left footpeg) and hook the positive lead to the starter motor top wire (usual disclaimer applies, do at your own risk) and the negative to a solid metal part without paint.
In the long run – although you can use the 12 V socket you may be better off by plugging gender specific connector with wires to the battery terminals and route the wires under the front seat. The 12 V socket of course will work well, but make sure you add inline fuse as any bastard with a piece of wire or metal object and malicious intent can fry your battery.
Nakigara wrote:On my Rockster the plug itself was an option. If I remember correctly, the plug itself was around $15 and installs in a hole on your starter cover that has a blank plug that you need to remove. There is a small quick connect to the wire loom behind this cover that the new plug will snap into. I don't know why BMW didn't just put this on the bike in the first place?? Hope this helps!
Dan
cheers Dan,
it is strange why they don`t fit them to rocksters as standard ,for the sake of £7.50($15), not to much of a issue i`ll just buy one,
thanks again Gaz
Nice one Duke, just the info i was looking for can i jump start my bike from the starter as described above as i now have the the click...click...click... when trying to start, only need to start to drive to a freinds where he is kindly going to change my battery, bump starting is not possible as my house is at the bottom of a slope,duke wrote:If I am not mistaken the 12 V socket was not factory installed for the European (or at least UK) Rocksters.
thanks Gaz
Sure you can, I have done it earlier this year when my bike was left motionless for 1 month in the cold and the battery drained below acceptable.gaz h wrote:can i jump start my bike from the starter
Use voltmeter to confirm where to hook if unsure.
Cheers
I have a connector to the battery under the seat right at the front. I can plug in an optimax charger there. Seems to work fine and am pretty sure it is BMW factory installed.
UK - Hampshire
Suzuki 600 Bandit - 00-04
Yamaha V-MAX 1200 04-08
Rockster 08 -
Rockster 08 -
hi again, managed to jump start off a car battery onto the starter motor top nut, didn't start straight away had to leave it 5 then it sprung to life first try got to my mates removed the tank and installed a p680 Odyssey battery took about 40 Min's and she fires up first time every now jobs a good-un,
cheers Gaz
cheers Gaz
Perhaps you could upload a picture of this?ROBOX wrote:I have a connector to the battery under the seat right at the front. I can plug in an optimax charger there. Seems to work fine and am pretty sure it is BMW factory installed.
ibux
'08 Titan Silver Metallic / Magma Red R1200S
ibux wrote:Perhaps you could upload a picture of this?ROBOX wrote:I have a connector to the battery under the seat right at the front. I can plug in an optimax charger there. Seems to work fine and am pretty sure it is BMW factory installed.
I got it installed under my seat too, no idea if this was done later.
See picture of charging socket under the seat. Makes charging the battery easy. Hope this helps.
http://i253.photobucket.com/albums/hh42 ... G_4389.jpg
UK - Hampshire
Rockster 08 -
Rockster 08 -
ronnierockster
Looks like someone fitted an optimate type connector for charging batt under your seat. Gaz H how easy was the terminal connections on the Oddesy battery. I have just ordered one and was thinking of making two posts from bits of angle to bolt to the battery with a hole in to take the existing leads.. Waddayathink???
See Ya...RR
There are L shaped connectors that are available for these batteries i think i've seen them on ebay somewhere. I managed to carefuly bend the terminal connectors so they sat in position on top of the battery, works fine good solid connection, superb battery.ronnierockster wrote:Looks like someone fitted an optimate type connector for charging batt under your seat. Gaz H how easy was the terminal connections on the Oddesy battery. I have just ordered one and was thinking of making two posts from bits of angle to bolt to the battery with a hole in to take the existing leads.. Waddayathink???
