With the mileage I've been putting on my bike, doing my own maintenance has become a necessity for me. Besides saving money, I'm getting more familiar with the working's of my bike by doing so. Knowledge that could come in handy on trips when I might be in the middle of nowhere with a breakdown...
**This is not a comprehensive DIY guide of how to do maintenance on your bike, more of an example of what you can do yourself if you're motivated to do so.
Let me start with the info I had in order to do this.
I ordered a Jim von Baden instructional DVD and a bootleg BMW Service Manual off of ebay.
http://www.jimvonbaden.com/
Jim's DVD and the BMW DVD have all of the info one might need to do all of the maintenance, without both of them I would have been lost. If you're like me and had never done most of this kind of work before, I recommend getting both to start...
I ripped Jim's DVD down so I could load it on my iPhone to watch, while keeping the BMW service manual program running in windows on my Mac.
I'm not going to list the rest of the tools.... it's all in the DVD's. I'll just take you through what I did in a non-technical way.... if that makes any sense.
I went to MotoWorks to get most of my filters and fluids, what I couldn't get there I picked up at Chicago BMW. Both dealers were helpful getting me everything I needed, and after they knew the miles I had put on my bike this year were understanding as to why I was doing it my myself.
Tools and stuff
Changing the air filter:
First I removed the side covers
pushed in these two clips and gave it a good pull
then pulled out this tab
new filter in place
At this time I put everything back together in the opposite order..
Then I also drained the engine oil and removed the oil filter, no pics of me spilling oil all over my floor, I really need to invest in better catch pans...
Transmission Oil Change
Removed fill plug
Removed drain plug
Drained oil
While the gear box and engine oil were draining I started on the final drive oil by removing the exhaust can, you can just rotate the can, but I decided to just take it all the way off.
After removing the rear wheel, I then removed this nut, leaving the bolt in place.
removed the brake
I then hung the brake out of the way with a rok strap.
loosened the speed sensor
removed the clip holding the wire going to the speed sensor
pull the wire out of the other clip
removed the speed sensor, the sensor is magnetic and in Jim's DVD he had a bit of metal flakes to clean off, mine didn't have any.
After removing the bolt holding the rear end to the ( telelever? ) I gave it a good pull and it popped down like this
I then removed all of the old grease and applied a generous amount of new grease.
New grease on the boot too
It took a few tries to get the spline lined back up, and some forceful pushing, but it eventually went back together.
installed the drain plug, with a new o-ring.
Filling the final drive, it does take about 4-5 minutes to do like Jim says, rotating the brakes to get the oil down in there.
After filling the rear end with the proper amount of oil I replaced the speed sensor, clip, and installed a new nut on the bolt holding the telelever as per BMW recommends.
After replacing the drain plug I then moved on to fill the gear box with the proper amount of oil, using a different bottle of course.
Time to do the valves.
This is where I had a problem. It appeared that the rubber insert from my spark plug socket had stuck to the spark plug from the last time I did my valves and was now wedged in there.
I ended up needing to take a drill to it to break it apart and pull it out piece by piece. It was a little disturbing to be taking a drill to my bike, but I managed to not damage anything, and spent plenty of time cleaning the plastic bits out...
On with adjusting the valves, go to go here, no need to adjust...
I did need to do a little adjusting here, but it doesn't really take too long, though every time I do it, it seems I take more time because I'm obsessed with them being perfectly matched.
intake
exhaust
After I did both sides I put everything back together, I replaced the spark plugs, filter ,and oil with new one's.
After inspecting the rest of the bike, and filling my tires I was good to go South in January. While on this trip I knew I was going to need to change the rear tire, so carrying my spare, I planned on doing it myself, but because of weather related things I ended up going to a dealer in Tampa to have the tire changed. While they were changing it I asked if they could hook the bike up to the BMW computer and balance the throttle's, which they did, and only charged me for 15 minutes of labor.
Since this service I put 3500 more miles on my bike, it hasn't burned any oil and has been running great!
Like I said this isn't exactly a comprehensive DIY, more for entertainment purposes really. If I can do it.......
I hope you enjoyed!
