Ideas for installing a GPS
bmwr1150rbmw
Post by bmwr1150rbmw »
Does anyone have a home remedy for attaching a GPS to the bike. The aftermarket options seem limited and a bit obtrusive. There seems to be very little room on the handlebar.
I have a 04 r1150r and a Mio c220 which is approximately a 5 inch by 4 inch GPS unit. (The Mio c220).
I have considered attaching the round suction cup plate to the top of my my tankless bag but then I have to have the bag attached when I use the GPS.
Any home remedies out there? Thanks.
awagnon
Post by awagnon »
Lots of people mount theirs on their tank bag. I didn't because it seems too insecure or unsteady. Also, I ride more without the bag and still like to have my GPS. I used a RAM mount as in the pictures. The Powerlet outlet is to power the GPS. I've since removed the thermometer as it's very inaccurate in this location. I usually use a smaller Garmin GPS 60CSX, but occasionally a ZUMO which is about the same size as yours and it doesn't seem to be that intrusive. Also, I use the speedometer on the GPS, so I don't mind if the bike's speedo is covered up by the GPS.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
taosports
Post by taosports »
Interesting that you consider most after market options "a bit obtrusive" and yet want to attach a 5 X 4" monster of a gps on your bike. :shock:
Anyway, DO NOT use the suction cup on your tank. They may work great on the protective interior of a car windshield but that is entirely different than the exterior of a round gas tank exposed to the elements.
I'd look further into the after market options if I were you. There are all kinds that mount anywhere you want and not just on the handlebar.
Here is my set up with a mount by TechMount. It works for me.
Good luck on your search!
bmwr1150rbmw
How about using the suction cup mount that came with the unit, primarily used to mount to a car windshield, on the rpm/tachometer display? It fits. Thoughts?
bmwr1150rbmw
Michael, I like your techmount system. Question-How is you Garmin attached to the mount? From Techmounts website, it appears that I would have to figure a way to attach my GPS to the Techmount. Velcro? Thanks,
ScooterCop
Post by ScooterCop »
bmwr1150rbmw wrote:How about using the suction cup mount that came with the unit, primarily used to mount to a car windshield, on the rpm/tachometer display? It fits. Thoughts?
I don't think anybody here would trust that way of mounting. I use the Techmount short arm, with a Garmin Streetpilot 2820, and GXM 30, connected to an Autocom, with etymotic earplug headphones in my helmet.
2004 R1150R ABS
2004 Piaggio BV200 (for work use only!!!)
taosports
Post by taosports »
bmwr1150rbmw wrote:Michael, I like your techmount system. Question-How is you Garmin attached to the mount? From Techmounts website, it appears that I would have to figure a way to attach my GPS to the Techmount. Velcro? Thanks,
Yes, it's attached using the velcro Techmount supplies. The reason for this is that I rarely use the gps so when I am not using it, the gps mount is detached from the Techmount and out of sight leaving me the velcro surface of the Techmount for other things like a bridge toll transponder or my Ipod remote. It's more versatile that way. Note that the Techmount has holes drilled into it for a more permanent, secure mount of whatever you want to attach to it.
Dr. Strangelove
Post by Dr. Strangelove »
I too use the Tech Mount for my Zumo--pictures will follow
There is a plate that comes with the techmount that the zumo cradle securely screws into with 4 screws.
I really like the tech mount. They were very good people to deal with and their product has an elegance about it that RAM mounts lack--ymmv.
I have the zumo mounted to the left and on a second techmount is my sirius starmate radio. I have them adjusted do that they neither hit my tank bag, nor block the view of my dashboard.
BTW I have the silver bracket that attaches to the handlebars, but got the black plate. I think it looks better that way because the backs of the zumo cradle and the sirius are both black. Makes it look mor "finished."
I will try to post the pictures tomorrow--the tech mounts go for $69 + shipping and they are worth it.
'09 Schwarze Blanche DuBois
Arbreacames
Post by Arbreacames »
The easiest way would be to drill a couple of holes on both side of the mount below and zip-lock it onto the handlebar. I do the same on a similar GPS. For shock absorption, you can stick some rubber tubes into the heads of the four Allen bolts that hold the hadlebar.
http://www.semsons.com/miofabrdehof.html
Carlos D.
bmwr1150rbmw
Thank you all for the ideas and insight. I broke down and ordered the Techmount short arm in silver. I like the fact that I can velcro all sorts of stuff. Thanks again.
