Who skips annual ABS service?
Post by 1150929 »
Hi guys, some advice needed.
I've only put 2500kms on my R since my last ABS service...in spring of 2006! :oops: ...long story for the low kms, love the R, but with 2 kids, three bikes, countless projects, yada yada...
Do I really need to service it for thr '08 season, and if so, why (mechanically speaking)?
Rui
'03 R1150R silver w/abs,black motor,bags,backrest,givi
'00 CBR929RR
'08 Road King Classic
Biff's R
Donating Member #: 289
Post by Biff's R »
If the fluid is ok, then don't worry about it. On the bikes with the ss brake lines, they(BMW) say you can go 2 years. I would suggest that you get out and ride more in '08.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
Donating Member #: 312
Post by boxermania »
Brake fluid is hygroscopic, this is one of the reasons to service, read change and flush, the brake system as the water collected tends to acumulate and create rust in due time.
In your case, being in Canada and with so little use on the bike I will look at the color of the brake fluid. If its clear let it go, if it has taken a slight brownish tint you might consider changing.
There are several of us that ride the brand and live in Louisiana, read high humidity, and we change/flush every 2 years with no problems.
I'm sure other users will have differing oppinions, I'm sharing what works for us. 8)
awagnon
Post by awagnon »
I could be wrong, but I thought the current recommendation was to flush the upper circuit every two years and the lower circuit yearly. Actually, it isn't that difficult of a job, especially on an R-bike where the biggest chore is just removing the tank.
On the other hand, the fluid always looks good, even when doing the every two year upper flush, so the current recommendation is probably overkill and every two years for the entire system is probably OK.
Al
Ogden, Utah
2002 R1150RT
2004 R1150R (sold) (sigh...)
2004 R 1150GS
DJ Downunder
Post by DJ Downunder »
If it were me I'd do the brake fluid every second year..but change the clutch fluid every year..as to stop the chance of clutch slave cylinder problems.
awagnon
Post by awagnon »
DJ Downunder wrote:If it were me I'd do the brake fluid every second year..but change the clutch fluid every year..as to stop the chance of clutch slave cylinder problems.
Actually, DJ, that's not a bad idea. I just changed the clutch slave cylinder on my RT and it's a major job. I think I'll start changing the fluid yearly. Also not a difficult job if you just take off the ball-valve thingy and leave a regular brake bleeder on in its place all the time.
Al
Ogden, Utah
2002 R1150RT
2004 R 1150GS
1150929
Post by 1150929 »
Thanks for the wise advice all, you're a fine bunch.
The fluid couldn't be clearer and I do have the SS lines, but I guess I'll still change it since it's year 2. Still, I don't get why its ABS system needs more maintenance than a car :?
And thanks for the reminder about the clutch fluid. And yes, I WILL ride more in '08, my mental health depends on it!!
Rui
'00 CBR929RR
acejones
Post by acejones »
It needs frequent service so the BMW dealer can send his kid to a fine college and still retire early.
Gary C
Post by Gary C »
How can you tell if you have ss brake lines?
DJ Downunder
Non ss (stainless steel) brake lines are black rubber looking..ss look silver metalic..I think they all went to ss lines after about 04.
allanj255
Post by allanj255 »
You can get ready made fluid changing/bleeding kits for Beemers off Ebay for a few dollars
Allan
2003 R1150R Twin Spark, (Black - the fastest colour)
P_Jensen
Donating Member #: 1130
Brake Fluid Change
Post by P_Jensen »
The one maint item I would not skip is the brake/clutch fluid change. As stated above over time the brake fluid absorbs water which if left in there long enough will cause corrosion . I would rather pay to have the fulid changed than replace an ABS system because of corrosion. I have the brake fluid flushed in my cars as well, ABS systems are just as expensive for cars as for the R.
P Jensen
14 R1200R
Montego Blue
NW VT USA
1150929
Post by 1150929 »
My Canadian spec '03 (build date March '03) has the SS lines, and the twin spark heads, maybe that was the first month of the switchover.
But while I get the whole moisture in the system thing, I still don't get why it's any more of an issue on the bike than a car. Nobody needs to change their brake fluid in their car every one or two years.
Rui
'00 CBR929RR
BITS806
Post by BITS806 »
A buddy was looking at buying a 05 rock, and when he brought up the maint on the abs the guy he was talking to told him since they have now had more time with the servo abs that bmw now suggests a period of 4 or 5 years, I can't remember which now. But it had atleast doubled.
