BMW Touring Shield
BMW Touring Shield
Does anybody know if the Touring shield will fit on the Sport shield (not the flyscreen) brackets? I have a sport shield and would like to go to a larger screen for winter riding. Also can you buy just the shield and do they come in a darkor smoke tint?
windshield exchange
Yes, if your using stock BMW brackets on the sports shield and want to exchange the windshield the touring windshield will fit perfect I'm not sure if the touring windshield comes in smoked.
Re: windshield exchange
Ok, senility is setting in, I admit, but which is the Sports shield & which is the touring?lombo wrote:Yes, if your using stock BMW brackets on the sports shield and want to exchange the windshield the touring windshield will fit perfect I'm not sure if the touring windshield comes in smoked.
Is someone able to post a picture - or two ?
Martyn Hillier, Cheltenham, UK.
1979 R100RT, 2013 R1200RT, 2014 R1200R & 2016 R1200RT Iconic.
I would appreciate someone describing, or even better, illustrating, which screen is which - Sports v Touring,Martyn wrote:Ok, senility is setting in, I admit, but which is the Sports shield & which is the touring?lombo wrote:Yes, if your using stock BMW brackets on the sports shield and want to exchange the windshield the touring windshield will fit perfect I'm not sure if the touring windshield comes in smoked.
Sport Shield
Touring Shield
Both of these use the exact same mounting apparatus..4 connection points with the rear ones up under the triple tree using those "impossible to access" 6mm hex screws.
Touring Shield
BMW touring shield
You sir, are a gent.
I've got neither of those - not the "flyscreen" either.
It's best described as a bigger version of the flyscreen & yes, it's BMW not aftermarket
That's the one that I have now have on my 1150R, having replaced my flyscreen.hirsty wrote:Those are the three BMW options though, small medium or large.
This is a better picture of the Sport shield:
Thanks,
I went down in the gravel about a month ago and bent the brackets on my flyscree. I was trying to remove the brackets this weekend in an attempt to straighten them as much as possible. I encountered the "Impossible to access 6mm bolts". Managed to get one free but the other is still hanging on. Any ideas on how to get at these?
thanks,
Brady
thanks,
Brady
If you use a ball end hex wrench (e.g. Bondhus) held by locking pliers (e.g., Vise Grip or Facom) you can get sufficient torque to loosen and tighten those hard-to-reach bolts. You might want to put a towel or something like that on your tank to protect it in case you slip and drop your tools.mcollect wrote:You need a long ball end hex wrench. otherwise it is next to impossible to get one side off.
Bob
2002 Atlanta Blue
Lifetime Member #74
2002 Atlanta Blue
Lifetime Member #74
Ball End with Helper
I have a set of cheap ball-end allen keys that are longer than the garden variety. These work great on many hard to reach bolts.Brady wrote:Any ideas on how to get at these?
To tighten/loosen those lower w/s mounting bolts I slide a box end wrench over the end of the allen key to use as a cheater bar.
Run down to Sears or your favorite tool store and grab one of these and a longish 3/8" extension. These tools make those "ITA" 6mm bolts easy to get to.Brady wrote:I went down in the gravel about a month ago and bent the brackets on my flyscree. I was trying to remove the brackets this weekend in an attempt to straighten them as much as possible. I encountered the "Impossible to access 6mm bolts". Managed to get one free but the other is still hanging on. Any ideas on how to get at these?
thanks,
Brady
scottybooj
