Center stand when lowering the R 1150 R ?
LRMR1200RT
Post by LRMR1200RT »
I'm about to install Wilber shorter shocks to lower the '04 R 1150 R. The parts include a shortened side stand. I'km checking about the availability of a shortened center stand? Has anyone performed this to their R? If so, how did it work out for you?
Larry
NorCal
Larry
DJ Downunder
Post by DJ Downunder »
Just wondering...The shorter side stand sorta makes sence..But I don't see why you would need a shorter center stand.
The wheel would just sit a little higher off the ground when on the center stand..that's all..IMO.
Or am I missing something here?
Boxer
Donating Member #: 2
Post by Boxer »
DJ,
The center stand would hit the ground too far back for it to be lifted up without great strength. Far too much for a person needing a shorter bike usually...unless it were Pat.
mvscorpio
Post by mvscorpio »
I know of someone who had a welder shorten the center stand for that reason - too hard to get the bike up on it.
Maria
2004 Silver R1150R - The Fastest Color
DJ Downunder
Ok...I can see now that it's also a leverage thing.
bruno71
Donating Member #: 495
Post by bruno71 »
Larry,
The center stand can be shortened by a good welder/fabricator, but he/she must pay attention to warping and properly fitting the stand to the bike. The shop I take my bike to has a long relationship with a professional fabrication shop that does the work for about $200. It is best to take it to someone that can do the work while having the bike handy for proper fitting. If you want the info for the guy here in SLC, UT, drop me a line and I'll send you the info.
LRMR1200RT
Shorter Center stand
Thanks to all who replied. I will check into welders/fabricators here near Sac and hopefully will find a good one.
Larry :)
Larry
Eddiem
Center Stand Balance
Post by Eddiem »
Aloha
I think that leaving the center stand the way it is may be a problem because as you all know the mechanical leverage that you use to lift the bike into the center stand is significant. If the center stand is to be left at the same lenght I think that you may have some muscle issues rolling the bike on the center stand due to additional distance the bike has to travel after being lowered.....
As some of the guys and gals mentioned, you should be able to have the center stand shortened by a good welder.
Good luck!
Mahalo Nui!
EM
R-1150 RS (ABS)
Starting to Like Power Assisted Brakes!
Honda XR 650 (Gone)
MadrasGiaguari
Post by MadrasGiaguari »
Merry Christmass to all the friends of this Forum!
Dear Larry,
could you pls resume the benefits and the why-not, of lowering our R1150R?
Thank you
Angelo :lol: :lol:
LRMR1200RT
Lowered the R 1150 R
The Wilber shocks are installed and the riding position is much better with significant improvement in control while stopped.
The side stand kit worked well and the center stand is still being fabricated . Should be completed soon.
Overall, the lowering kit has been a great success.
Larry
Larry
