\Mike_Lea// wrote:Can't answer your query, but I'd be interested to know if you fitted the center stand yourself? If so, was it an easy job?
Hi Mike. Yeah I did it myself... It didn't seem too bad..
What I did was ordered all the parts on the parts fische over at maxbmwmotorcycles.com. I left out the bracket that the sidestand attaches too which was 107 bucks. The dealer had included that during an estimate once and I was psyched to find I already had that piece when i started comparing part numbers to the sidestand diagram.
I accidently ordered the fillister bolts and respective washers... seems i had all of those already too...could save another 6 or 7 bucks on those...
Also accidently orderd the piece the spring attaches too on the right side doh that was 12 bucks! Will try to return these items.
So I had to remove some bolt type bushings spacers for lack of a better name that the bmw I-don't-have-a-centerstand Lift hooks onto... I was a little concerned about loosening up things near the sidestand so I put the bike in a front wheel chock I got from powerstands.com. attached tie downs to the front fork. The chock is allright but it needs to be bolted down in my opinion... was a little wobbly! Someone mentioned they installed there centerstand without any type of lift or stand but since i had it I put it to use.
Installed the center stand and spacers, bolts with orings and the bmw sidestand/centerstand pivot grease... blue loctite didn't have 243 so used permatex 242 blue. torqued to 21nm...
Getting those springs on was a pain, seen a pick of someone stretching it and sticking pennies in between the coils but I finally decided to use the hook end of an auto brake spring tool and it was much easer...
