http://www.flickr.com/photos/rockburner ... 8211/show/
For starters:
get out the tools.
Adjustable pliers
hex key
brake cleaner
hi-temp brake grease
copaslip
needle pliers or circlip pliers
toothbrush.
gloves
I have a seat that makes life a lot easier.
The correct material for absorption is critical.
Loosen the caliper bolts (don't remove them yet)
Take off the spring retaining screws (they're tiny so take care)
The definition of manky brakes!
hoik out the retaining pin with the circlip/needle pliers
slide out the retaining pin. This one was a bit stuck but came out with a bit of twisting, utilising a set of gripped needle nose pliers.
Here's where the brake cleaner comes in....
... and the toothbush.
using the brake lever, push the pistons out a BIT (this is about as far as you want to take it. One trick I use is to keep the old pads in place and use them as "stops" to prevent the pistons extruding too far.) You can see the lines where the dirt has been pushed past the weather seal.
once you have all the crap off, (this particular job wasn't perfect, I'd need to strip the calipers completely to get all of it off - mainly because I left the bike filthy for 8 weeks.
give the calipers another going over with the toothbrush once you get the pistons all the way back in.
Give the spring plate a clean.
This brush is a Bonsai tree soft brass bristle brush for cleaning the tree trunks - PERFECT for cleaning things like this.
BMW's hi-temp brake grease. you want a bit more than this for the back of each caliper.
I spread the grease by rubbing the calipers together back to back.
a clean retaining pin.
a nicely greased pin - note the glob of grease on the end. This is important. This is how i could slip the retaining pin out of the filthy caliper after 3 months of winter. When you put the pin back in - ensure that glob of grease stays on the end until it gets into the blind hole in the caliper. Also see the pads back in the caliper, if you're careful they'll sit there for the time being.
caliper back together and on the disc.
copaslip on the caliper bolt.
smear the copaslip into the threads. Make sure the end of the bolt is clear of copaslip.
Copaslip on the spring plate screw. DON'T get it on your fingers - cos you'll drop the fecker getting it back into the caliper!
Almost there. Get the spring plate screws in before tightening up the caliper bolts.
30Nm according to the handbook...... (I normally just do them up as tight as I can by hand)
pump up the brakes again before you move to the next caliper and do it all again!
Now to bleed em...
All you need is the right screwdriver, a 10m spanner, some hose, a wine bottle (yes the vintage helps....
I have duct tape over the reservoirs to keep the joins clean from insect debris and crap.
Even so - give the reservoirs a clean with brake cleaner and a rag.
Keep the reservoir as flat as possible when filling.
Keep the rubber seal over the reservoir while you work - you don't necessarily need to put the whole cover back on.
The caliper kit.
Hook the hose to the bleed nipple, make sure the bottle is in a stable position.
Make sure the spanner has plenty of room for manouvre.
Pressurise the system by pumping the lever about 5 times, then HOLD it tight. Then release the pressure at the bleed nipple by turning the spanner. As SOON as the fluid stops moving close the nipple again. Repeat this a few times, checking every 5 or 6 cycles to check the fluid in the resevoir.
get everything done up and tidied away - new tape for the resevoir.
Any questions??
