Anyone taken their bike WAY apart?
I need to swap out my rear frame for one I've done some mods to and I'm just wondering if it can be done without removing as many components as Clymer indicates.
Anyone?
TIA!
Anyone?
TIA!
Well for statrters, you have to remove the tank, all the plastic, fender and electrical cabling, disconect the shock at the top, cut all the wire ties that hold the wiring to the frame........ not dificult but tedious. It helps a lot if you have a bike lift.....from one that has done it a couple of times.
You might consider powder coating the new frame, it looks awesome.
Ahh, here we go..the voice of experience!
So, no way to snake that back without taking the tank off then?
Can the tank just be pivoted up?
I'm trying to avoid having the bike down too long and with my schedule that's a potential.
Powder coat would have been overkill with the amount of frame actually exposed so Krylon got the nod.
And I do have a lift. What a treat, eh? These old knees ya know.
Grey,
Removed my airbox and that required removing the rear subframe. Pretty labor intensive. Not real difficult. Make sure you have an 8mm torx that fits onto a rachet. Stripped mine with the allen type wrench.
P.S. oH YEA, REMEMBERto put your fuse box in before the frame stiffener on re assembly.
04 citrus Rockster
00 XR400R ( for gettin dirty)
04 CRF150F (My son gets dirty too)
- CycleRob
Greybeard,
The 50R is an easy bike to work on. Especially if you have any experience working on other brands. Just about every "project" I initially dreaded; the annual service, removing the heads, changing the shocks, changing both tires, upgrading both CamChain tensioners . . . . all turned out to be easier than I expected. It's all just easy busy work, like previous posters say.
Since you must cut all wire harness attachment points to replace the frame and the 4 frame bolts are visible with the tank on, I too would have tried "pulling it straight back, fueltank on" to swap the frames.
-BUT -
It looks like the airbox's captive shape may prevent that. Also, none of the BMW service procedures recommend that method and there is prolly a good (hidden) reason why. Give it a try anyway. You could help pave new ground for the group IF it is successful.
I'd say you're looking at only a rainy or designated weekend project, NOT a wait-till-Winter project. Just rely on Pepsi (caffeine) and printouts of the CD Manual pages . . . instead of . . . . Bud Lites (ethanol) and rock music for your companions.
-BUT -
