A couple of pics of Ohlins shocks
fnfalman
Post by fnfalman »
Front & rear Ohlins shocks for the Rock.
hirsty
Post by hirsty »
Very pretty.
Did you fit them yourself? How'd it go? Worth the money vs stock? etc etc ...
fnfalman
Post by fnfalman »
I didn't put them on myself, but those shocks are fairly easy to disassemble and swap out.
And yes, it's worth every red cent. The ride is more compliant yet stable without feeling the wallowing, especially during hard cornering at high lean angles. Consider that they aren't any more expensive than the Tokico crap that BMW tries to foist off on its customers AND they're rebuildable, yeah, worth every red cent.
Lion_Lady
Post by Lion_Lady »
I put mine on myself (okay, hubby helped with the "muscle" parts)!
Yes. Definitely worth it! And I switched out when my OEM shocks were still in good shape (for use when I get the Ohlins rebuilt). Felt like a new bike.
P
fnfalman wrote:I didn't put them on myself, but those shocks are fairly easy to disassemble and swap out.
errr - Tokico make the brakes, (if they're not Brembos)
I think the shocks might be from Showa.
HTH ;)
fnfalman
Post by fnfalman »
Well, you know what I mean, Tokico, Showa, Jap craps. I am also disappointed that BMW didn't put Brembo on the Rock as well. I'm really sorry that I got the bike with the ABS and the stupid servo assist because I really want to upgrade the brakes to Brembo.
MartyWadd
Post by MartyWadd »
My Ed 80 has Brembo calipers. Don't they all?
MartyWadd wrote:My Ed 80 has Brembo calipers. Don't they all?
Mine has Tokicos.
Boxer
Donating Member #: 2
Post by Boxer »
fnfalman-You want to sell that rear Showa shock you took off?
sweatmark
Septuple Lifer
Donating Member #: 208
Brakes & shocks
Post by sweatmark »
How does one discover the OEM for Roadster/Rockster brake calipers?
fnfalman, I'm with you re: the servo brakes... the ABS-ectomy appears do-able, with a small handful of parts required to make it happen. This will be on the ToDo list when my Ed80's warranty expires.
We don't talk much about brake upgrades here on the board. Anyone with experience/evidence that caliper replacement will significantly improve braking performance?
Oh, and this thread serves as good reminder that the Mrs. and I need to install her Roadster's Ohlins! (We haven't ridden much this season.)
Biff's R
Donating Member #: 289
Post by Biff's R »
I think I read somewhere that the San Jose Race team tried different brake pads and rotors, etc, and found the OEM to work the best on the R1200S.
Jeff (lifer #289)
'17 F800GSA
'04 R1150R
iowabeakster
Post by iowabeakster »
If you look at the inside half (closer to the hub) of the caliper, (looking through the wheel from the opposite side) you will probably see "Tokico".
arbik
protect them...
Post by arbik »
Ohlins Rock!
I've tried other brands, and I'm sold on their magic.
I've had them on my Rockster for a while now, and they are just amazing.
One thing though. The Ohlins shock up front, is exposed. That means, the shaft sees everything on the road coming at it.
What i did to mine, was I cut a water bottle, and fit it over the springs, as to protect the shaft from debris. Sure, it doesnt look as good, but it'll definitely save your seal from leaking prematurely.
as for what type of water bottle, I use a smart water bottle, cut just right, at the neck, as to not slip below the first loop on the spring from the bottom.
Cheers!!
-arbi
fnfalman
Post by fnfalman »
Boxer wrote:fnfalman-You want to sell that rear Showa shock you took off?
Sorry, it already went into the garbage dumpster. Trust me, there weren't anything left. :lol:
Also are you guys sure that the Ed 80 has Brembos? I find that a wee bit hard to believe because they don't stop any better than the standard Rock.
I don't know about the R1200S, but the Rock's brakes could use some more stopping power.
Anything that can do stoppies is good enough for me!! (and yes I CAN get the rear off the ground on the Rockster)
arbik
Post by arbik »
The Edition 80 and the Regular Rockster have the same front Brake calipers, and They're both made by Tokiko.
The R1100S bikes used to have different brakes. The standard R1100S bikes had the Tokiko brakes, and the R1100S Boxer Cup and Boxer Cup Prep bikes came with the Brembos.
You can tell by the configuration of the pins and screws on the calipers.
Having said this, I've owned both, and the Brembos arent any better than Tokikos. They're just more "racer bling", kinda like Ohlins are (although, for me, there isnt a substitue for Ohlins).
If your brakes on the Ed80 arent impressing you, then there is something defnitely wrong with them. Change the fluid, and bleed them well.
Mine on the Rockster are phenominal.
-arbi
fnfalman
Post by fnfalman »
riceburner wrote:Anything that can do stoppies is good enough for me!! (and yes I CAN get the rear off the ground on the Rockster)
I'd like to see you do a stoppie with an ABS-equipped Rockster. :wink:
The stopping power isn't bad for a big bike like that but the brakes do fade rather quickly when it comes to spirited riding.
Just one of the many reasons I DON'T want ABS... i want to have control of my brakes, thanks. ;)
