I made a list of R1200R seats with part numbers, to try to clear up some confusion with an ebay vendor, I thought I'd also copy the information here. This should probably be in a FAQ. Much of this is copied from the Max bmw site.
BMW R1200R seat part numbers.
52537713114 BENCH SEAT EXTRA-LOW - 760MM Supplied with low suspension option. Forward seating position.
52537698379 BENCH SEAT LOW - 770MM.
52537706416 BENCH SEAT - 800MM Standard on 2007-2010.
52537706418 BENCH SEAT HIGH - 835MM.
52537721957 COMFORT SADDLE LOW - 800MM. Has a strap.
52537719485 COMFORT SADDLE, LOW - 800MM. Has no strap, Standard seat on 2011+
52537721958 COMFORT SADDLE, HIGH - 830MM. Has a strap.
52537719484 COMFORT SADDLE, HIGH - 830MM 2011+ Has no strap.
R1200R seats.
Re: R1200R seats.
Very helpful. It's additional info I didn't have, more discriptive. Thank you, as I am trying to determine which Wunderlich seat to order. They ain't cheap.
Re: R1200R seats.
I tried BMW high comfort seat but didn't like the additional height. I also had some custom work done to my stock seat. Turns out I am really happy with my Airhawk, which is cheaper than a replacement comfort seat, and I can also use it on other motorcycles that I own or hope to own...
John K
2008 R1200R
2013 HP4
2008 R1200R
2013 HP4
Re: R1200R seats.
I am replacing my 52537706416 BENCH SEAT - 800MM Standard on 2007-2010 which i find very uncomfortable for a
52537721957 COMFORT SADDLE LOW - 800MM. Has a strap is there much difference between the two?
any commence will be appreciated.
Re: R1200R seats.
The comfort saddle is wider and more comfortable. All of the seats are interchangeable. You don't need the strap if you have the handles behind your seat. But the strap doesn't hurt anything.
zackvis wrote:I am replacing my 52537706416 BENCH SEAT - 800MM Standard on 2007-2010 which i find very uncomfortable for a
Re: R1200R seats.
........and BMW has again a newer seat: Comfort exclusive, 800 mm. Part number is 77 34 8 546 033.
Rob
Rob
Re: R1200R seats.
Thanks for taking time to make the seat list. Good info. Seats are a frequently swapped item.
Re: R1200R seats.
I took the high comfort seat and had Kontour rebuild it. Now it is an easy 8-10 hour seat !
Re: R1200R seats.
Hi all, I just recently picked up a 2012 R1200R CE with 152 miles on it! LONG time BMW owner and love the bike but I do have to say that the seat that was delivered with the bike, leaves a LOT to be desired, and I am one that NEVER has any problems with the stock seats! Hence my Nickname!
Looking through the catalog of available seats BMW lists a 52 53 7 706 416 Sport Seat, which looks a lot flatter than the humped whale that came on my bike!
But in this list it says that that seat came standard on 2007-2010 R1200R's. Does anyone have one of these seats in perfect condition that they would like to sell? Is that the flattest seat that BMW makes for this bike? Not so concerned with seat height, just don't need something so cupped.
Thanks and I look forward to being a Member here!
Phactory Phil
Phactory Phil
