Posted by Nick V 29-01-14 at UKGSer site.Alternatives:Denso IU27D;NGK CR9EIX-iridium tiped;NGK CR9E-non iridium.For installation have to use 16mm tube socket with max.outer diameter of 22mm.This socket FITS the spark plug hole.The MAR8B-JDS closest match is CR8EKB (commonly available).
This gentleman did this, so this is a fact.
Steve H.
MAR8B-JDS are not the only spark plugs that fit the DOHC eng
Re: MAR8B-JDS are not the only spark plugs that fit the DOHC
I did not try out these sparkplugs yet,synce I got 16 of MAR8B-JDS,so I am ok for a while.Just posted this, to help anyone in need for spark plugs for camhead r12r/gs/rt.It should work.It worked well for South African gentleman mentioned above.
best wishes
Steve H.
best wishes
Steve H.
I believe these are one heat range colder than stock. You may have to use IU24 and CR8 to match stock heat range.
Ted
2011 R1200R
2008 CVO Dyna
2003 Valkyrie
2011 R1200R
2008 CVO Dyna
2003 Valkyrie
