Checking my bike before riding to work this morning, I noticed a wet spot on top of the front master cylinder. Brake fluid. After cleaning it off, I discovered that the two little screws that hold the reservoir onto the cylinder body had loosened. The reservoir could rock and each time it rocked, a little bit of fluid came through the seal. Presumably there was enough motion while riding to account for the leak.
Just tightened the screws and now it's tight and (hopefully) the leak is stopped. But it would have been a real mess if the screws came all the way out and the reservoir popped off while under way.
Worth taking a minute to check...
Brake reservoir warning
- Double Lifer
Re: Brake reservoir warning
Thanks Neil!
One more little thing to keep an eye on!
Kyle
Kyle
#574
#574
Hi Neil,
My 2007 R1200R has developed the same weeping around the base of the reservoir. Did tightening up the screws stop the leak?
Does anyone know where can I get a front brake master cylinder repair kit?
Cheers,
Steve.
Cheers,
Steve.
Mine had similar weep a couple years ago and I too freaked thinking it was toast. I tightened the screw and pensively road it that way for a week or so. Then I forgot about it until I just read this. I think in my case it was a matter of the screws being a little less than snug, returning from a long morning ride heating the fluid, and letting the bike sit in the blazing sun further heating it.
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
Currently:
07 R1200R
07 XB12STT
10 FLHTP
12 Wee Strom ADV
