def, I question what you're saying here. I have run the CAT without the muffler, CAT with the muffler, stock muffler and Remus y-pipe, and briefly the one configuration I don't recommend, Remus y-pipe with no muffler. (Just to irritate the neighbors) I have never had heating problems. As well, I think quite a number of owners remove the stock muffler because they like the look or want to use the full sized RT left case. Using the stock silencer or the CAT means the sound won't change much. I don't think anyone here is really looking for performance with an exhaust change of this sort.def38 wrote:Your BMW dealer is correct. Modifying air flow through the boxer by removing the muffler, removing the CAT (illegal), employing after market air filters means the engine now receives more air for a given throttle setting. But are you adding more fuel along with this increase in air? Want more performance?.....loose 15 lbs.........want better handling?.....take an advanced rider course or buy some instructor/track time.beemerboy wrote:haha so taking off my muffler should not hurt the bike?
the bmw dealer said its gonna make it run lean and hot
As far as the airflow, I was interested in San Jose's airbox mod at one time because the airbox does restrict airflow. I don't really believe putting a K&N or whatever air filter will do much. The air box mod cuts a 4" hole in the airbox and increases the size of the airhorn. And guess what ? I asked a guy who did the mod, (he also added the aftermarket exhaust and chip) he only realized performance gains at the top end where he would normally run out of air. 136 mph instead of 124, or something like that. See what I mean ? If the intake is restricted, is the open exhaust actually going to lean out the mixture ? I'm not an expert, but I don't see it.
