Some questions before purchase
Posted: Sun Apr 22, 2007 1:17 pm
Hi all,
When examining a new R12R in the showroom yesterday, I noticed they still haven't put a drain plug on the final drive (this would cost what? a couple of bucks?).
Would it be possible to just insert a small plastic or silicone tube in the filler hole and push it to the bottom to siphon or suck the oil out?
I can't find the TB idle speed adjustment screw on the 12R. Did they hide it?
In order to clean and grease the tranny input splines (which I also had to do on my R100S 30 years ago), why couldn't you just unplug a few wires, remove TB inlet tubes, starter and muffler, remove 6 subframe bolts from the engine, unbolt the tranny, and pull the rear assembly back from the engine (after supporting the engine of course)?
Is the taller of the 3 seats taller because of more padding (more comfortable), or a different seat tray?
Thanks for any input. I just can't make up my mind about buying this bike.
Jim in Denton, TX
Jim in Denton, TX
