Rear end "twitch"
Invictus
Rear end "twitch"
Post by Invictus »
Granted, my R is the first shaft drive I have owned in over 20 years (I had an '80 Suzuki GS850 way back when), but I do not remember any twist or torque from the drive shaft. I assume the twitch I feel when accelerating hard on my R is from the single side swing arm, and normal for this bike. Comments???
H-D FLHTC
BMW R1150R
KTM 400SX
"Jodido pero Contento"
RBrider
Post by RBrider »
Probably has more to do with the crankshaft location , rather than type of rear suspension or final drive.
RB
Lion_Lady
Post by Lion_Lady »
Has to do with the side to side flat twin set up.
You won't have it on your front to back v-twins.
P
Ed K
Post by Ed K »
Invictus...
Twitch/twist under hard acceleration? Can you describe it in more detail?
I've accelerated hard thousands of times... and dont recall ever experiencing a twitch...
Are you riding a new R or used? How many miles?
Ed K
07 K1200S
Lifetime Member
johno
Post by johno »
As stated, it is probably the torque twist of the flat twin engine.
If high mileage, check the pivot bearings at the diff end on the drive housing, as I had worn bearings on my R1100RS I had. ( 40,000ks)
Also check tyre pressures, maybe low.
2002 R1150R.
gregor
Post by gregor »
Nope, never had a twitch from mine either.
Got the front end very light at 90 mph once but that's a different matter.
