metal oil filter-
Posted: Thu Sep 14, 2006 11:43 pm
by solitario11
now I hear everything,,,a metal oil filter, something like a K&N filter, you removed it,,wash it and put it back!
<http>
http://scottsonline.com/indexframe.html#feedback.htm
Posted: Fri Sep 15, 2006 6:58 am
by challey
I've been warned off of this and similar products by a number of knowlegeable mechanics and engineers. The root of the problem is that the claims exceed performance by a considerable margin. Simply put, the filter doesn't work as advertised. The advice I got was to stick with the OEM filter.
Posted: Fri Sep 15, 2006 12:15 pm
by Samiam
That reminds me of the toilet paper filters that were all the rage back in the '60s. Remember those? I had a friend in grad school who put one of those things on a new Mercedes and didn't change the oil or t-paper for thousands of miles. Also neglected to check the oil level. Sure enough, the engine fried and the warranty was void.
Posted: Fri Sep 15, 2006 6:52 pm
by HornHonker
Yes, I had a girlfriend back then that insisted I drive her dad's 65 Mustang convertable
He had a toilet paper filter in it and no amout of discussion could I persuade her that it was the wrong way to go. So I found other ways to take my mind off it.
OIL FILTER
Posted: Sat Sep 16, 2006 10:24 pm
by OU812
AC DELCO PF-53 CAN BE USED WITH NO PROBLEMS, PER A MODERATOR.
pf-53
Posted: Fri Sep 29, 2006 8:21 am
by OU812
I tried to put the BMW oil filter wrench on AC DELCO PF-53 at a local auto parts store. It was too small(the filter). So I am going for the K&N, it has a nut tack welded to the bottom of the filter for install.
