Awhile back someone had compiled a list of diferent filters, plugs, etc for our bikes. I thought I had saved the list, unfortunately I don't seem to be able to locate it.
Can someone repost?
Thanks,
Al
List of other brand name components to use on the R bikes
I believe Dallara's post on the ''maintenence' board has that info.
http://www.r1150r.org/board/viewtopic.p ... 1b569c9e8b
'02 R1150RA Blk (Sold)
2000 V11 Sport
'90 GS500 w/ wide wheels, inv forks, braced arm
2000 V11 Sport
The Kurch Man
dallara
Equipment List...
Hi, Guys...
That was the list I put together a long time ago and posted here.
Of course a couple of the moderators think that my
Hope it helps you folks out.
Cheers!
Dallara
, ya' know...posts are not what many consider valuable
Cheers!
Dallara
scottybooj
- r1150rider
"airbox lid trick"
It's been so long since I did this, but I remember modifying the "tabs" that go in the "slots" that form the "hinge" on the airbox lid. I think I filed off a little bit of the "tabs", which makes it possible to remove/reinstall the lid without having to remove the fuel tank. Sorry to be so vague, but if you take the tank off and eyeball the lid, it's pretty easy to figure out. I think it's a matter of being able to engage the tabs at a shallower angle, I sorta recall that it only required removal of about 1/8" off the end of the tabs.
Ed
Member #9
BMW, because loud brakes save lives...
Member #9
darthrider
Re: Equipment List...
D...the NGK Iridium plugs on that list have a factory gap of 1.1mm...thus the '-11' at the end of the plug number.Dallara wrote:Hi, Guys...
Of course a couple of the moderators think that my, ya' know...posts are not what many consider valuable![]()
Cheers!
Dallara
OE says .8mm or .031" or .032".
Any benefit to opening up the gap that much???
j magda
TripleLifer Member 454
Deep in the OH wasteland...
