Spline shaft lubrication time
bransan
Post by bransan »
I am at 75,000mi on My 04 R1150R.
I have been religious about maintenance with this bike.
I'm not sure i could love another machine as much as this one.
I need to replace the swing arm bearings because they are worn and I have it apart to do the spline shaft lube.
Several years ago I read about some bushings to replace the bearings, does anyone remember who had them?
Keep Your Stick On the Ice.
Listen to Me at kaxe.org
Railbender
Donating Member #: 689
Re: Spline shaft lubrication time
Post by Railbender »
http://advrider.com/index.php?threads/b ... s.1149024/
I put a set on my R1100R over a year ago and they seem to be working fine.
DAM650
Post by DAM650 »
http://nushings.com
these are cheaper, but i know nothing about them
2002F650GS ABS Black Betty 89K
2002R1150R ABS Misty Blue 48K
Sunbeemer
Donating Member #: 593
Post by Sunbeemer »
I'd recommend you do a little research about the bushing replacements for the swing arm bearings. There have been some problems with the ones from rubber chicken garage (sorry I can't remember the particulars), but I was considering them and waited a few years to see if they were working and read some posts (on this forum I think) that dissuaded me. I'll go back to the original bearings when I need to (soon). Search is your friend.
DAM650
Post by DAM650 »
Sunbeemer wrote:I'd recommend you do a little research about the bushing replacements for the swing arm bearings. There have been some problems with the ones from rubber chicken garage (sorry I can't remember the particulars), but I was considering them and waited a few years to see if they were working and read some posts (on this forum I think) that dissuaded me. I'll go back to the original bearings when I need to (soon). Search is your friend.
my bronze ones are deformed on one side. so not worth the money i am guessing.
there were in there when i bought the bike, and i just rotated to the smooth portion and reinstalled. if they start wiggling, i am gonna try the nushings
sweatmark
Septuple Lifer
Donating Member #: 208
Post by sweatmark »
These Paralever bushings look interesting:
http://www.beemershop.com/Merchant5/mer ... e=TRA11094
https://www.youtube.com/watch?v=WBt6ftaJ_0s
Different setup than the Rubber Chicken versions.
