1150r very red muffler !
Posted: Sun May 07, 2017 5:11 am
Good Morning,
Yesterday, I just wanted to travel around in the morning. Prepared everything, started the engine, it died. Started it again, died. Then with few adjustments for idling, it started to run, with coughing. Not frequently, but as if discharging periodically.
Then, I noticed that exhaust is not giving out smoke, then I realised a hot air from below, then the following situation, where the first muffler rear end is redddd !
http://www.pictaram.com/media/150814586 ... 2189433512
This morning, I had removed exhaust pipe, then the first muffler. Controlled the air in and air out with compressor, everything seems fine. What should I do ?
Do we have a method to clean the pipe ? The muffler ? Why it is red ?
I tought that exhaust is not giving the burnt gas outside.
