2000 R1100R Surging and Bucking
Posted: Sun Dec 18, 2016 5:16 pm
Just bought a 2000 R1100R from a close friend. Its a bike I know well; my friend has owned it since new and one that he has taken on several trips with me. Since picking it up, the surging/bucking has gotten to the point that it is unridable i.e. Safely. Here are some of the specifics:
1. It has ~34k kms
2. My friend put fuel stabilizer in the tank a week before I picked it up. He put "as much as indicated and then a little more"
3. While he has not kept any service records, he asserts it is up to date. Most servicing done a non-bmw/generic bike shop.
4. I have emptied the tank and added fresh fuel making no difference
5. When starting it, it will run roughly at idle and with throttle get progressively worse. It back fires, surges and when ridden, bucks to the point of almost throwing me off the bike
6. The ride home from his place was fine, however I do recall it running a little rough toward the end. On a subsequent ride, it was noticeably worse and the on my last ride, after changing the gas, it was at its worse. I had to turn around after ~1 km!
7. I intend to change the plugs and run some fuel injector clear through it
Tangentially, I changed the battery and began the process of replacing a faulty clutch switch. The wires to the switch have been clipped and I am trying to locate a long socket or other 11 mm spanner to remove the actual switch. NB: the switch is there primarily to allow you to start the bike in gear with the lever pulled and not be dependent on being in neutral to start. I don't believe either have any bearing on how it presently runs (if you can call it that).
Any thoughts on what else I might do before taking the bike in to a dealership would be greatly appreciated!
1. It has ~34k kms
