Do the K12RS mirrors vibrate like the originals?
Posted: Wed Sep 14, 2005 3:15 pm
by ofrogg
I've seen so many of you swapping out the Mickey Mouse ears for the KRS mirrors... do they vibrate the same amount?
yes
Posted: Wed Sep 14, 2005 4:56 pm
by cam
yes, same.
Posted: Wed Sep 14, 2005 6:52 pm
by FGanger
I have the K12 mirrors on my bike, but in truth I've never used the stock ones. I did replace the "Micky Mouse" mirrors on my K12 with the newer shaped ones that we know today. When I bought my R bike I just switched mirrors. :D
I did like the updated design better than the round one. I'm not sure about vibration, but it does give a wider view. For nothing else I would make the switch. :D
Good luck,
Frank
Posted: Wed Sep 14, 2005 9:46 pm
by CycleRob
ofrogg,
I found they are a little more blurry than the stock mirrors because they are lighter. My next modification to my biken (soon) is to drill a 1/4" hole in the mirror's plastic shell bottom portion and add headless bolts or studs and 1/4" ball bearings together with squirt shots of super power hot glue in between groups of steel part insertions. This "pile" would be added to the outboard portions of each mirror, using gravity with (removed) part orientation, until the mirror is about half full of glued together steel parts that are also stuck to the mirror glass and plastic mirror housing. I know this shadetree mechanic mod will kill at least 90% of the blurries. You can get the same clarity from each mirror if you just touch the outboard edge lightly with your thumb while riding.
Even with the very slightly heavier blurries, the K12RS mirrors are way better looking and the wider field of view is safer.
Posted: Thu Sep 15, 2005 6:16 am
by Boxer
Didn't Franklin Roosevelt once say the same thing about his wife? :P
Personally I kinda like the round mirrors. They repeat the round design of that gorgeous headlight. 8)
Re: Do the K12RS mirrors vibrate like the originals?
Posted: Thu Sep 15, 2005 8:32 am
by rdsmith3
ofrogg wrote:I've seen so many of you swapping out the Mickey Mouse ears for the KRS mirrors... do they vibrate the same amount?
yes, yes they do
Posted: Thu Sep 15, 2005 6:51 pm
by ladybeemer
But....they are way better when it comes to rear viewing, albeit blurry!
Post some pics Rob
Posted: Thu Sep 15, 2005 7:14 pm
by hotzuk
Hey Rob,
If you get a chance, post some picks of that mod that you are proposing. Would love to see the final result.
Bar Snake
Posted: Fri Sep 16, 2005 3:06 pm
by kjax909
I have the KRS mirrors and am planning to get a bar snake. Their website states that if you have internal dimples or internal wiring in the bar, you have to use the liquid version. I believe we have dimples, but not sure about wires. I've never had my grips off. If no internal wires, I'm going for the liquid option (no way would I inject hard setting liquid if there are wires in the bars--if my heated grips ever die I don't want to have to end up replacing the entire bar!). Will post results if I proceed.
Posted: Sun Sep 18, 2005 8:44 am
by FGanger
kjax909,
It doesn't say on the Web Site that one can replace wires within the bars, even with the liquid version. Can they be replaced if they go bad?
Frank
http://www.barsnake.com/products/barsnake.html
Posted: Sun Sep 18, 2005 8:52 am
by Wayno28
Have heard lead shot with small silicone plug at each end works
and is cheaper and removable.
K12RS mirrors
Posted: Sun Sep 18, 2005 7:40 pm
by BMikeW
I have had two sets of K12RS mirrors. The actual mirror gets loose in the housing and vibrates (rattles!!!-even with ear plugs!!!). My local dealer (Blue Moon Cycle-Norcross, GA), but when the second set began rattling, I decided to make my own fix. I took some of that double sided sticky foam tape that we us in the automotive industry to hold on emblems and all kind of stuff and cut very thin strips and stuffed them at the right and left edges of the mirror. I now have vibratio free (relatively-it is a twin you know) and QUIET mirrors. I wonder if the K12RS guys have this problem??
Mike
Posted: Sun Sep 18, 2005 7:41 pm
by Guest
Hello again,
I meant to say Blue Moon Cycle warrantied the first set for rattling. Sorry!
Mike
