Fuel sending sensor
Posted: Fri Oct 24, 2014 1:45 pm
by Cohiba54
Can anyone tell me what kind of signal the in tank sending sensor makes? Is it an on/off or graduated signal?
Re: Fuel sending sensor
Posted: Fri Oct 24, 2014 6:21 pm
by towerworker
As far as I know it's on/off. There is a float device that I think triggers a switch. Then a low fuel lamp is triggered. I've had mine out but it's been several years and I'm working from a poor memory. But just the fact that a low fuel lamp is either on or off tells me that's it's a simple on/off device.
Posted: Sat Oct 25, 2014 8:48 am
by sstein
My 02R has a float device in the tank with a glass reed switch that is triggered by a magnet float. On-off only.
Posted: Mon Oct 27, 2014 9:58 am
by Cohiba54
Anyone know for sure on the '04 model on/off or graduated? I figured on/off for sure because of the light but thought maybe it's a graduated signal to the computer then an on/off to the light.
If it turns out that it's graduated then to the computer, I would intercept the signal before the computer and install something like this.
http://www.oreillyauto.com/site/c/detai ... &ppt=C0134
BTW - I found the range limit to an empty tank this weekend 187 miles, about 1000 yards short of the Shell gas station I exited for. Yes, it was up hill of my stop point.....
Posted: Mon Oct 27, 2014 10:52 am
by peels
Cohiba54 wrote:Anyone know for sure on the '04 model on/off or graduated? I figured on/off for sure because of the light but thought maybe it's a graduated signal to the computer then an on/off to the light.
pretty sure thats on/off only.
and LOL, ive had nearly the same experience. highway is 200, city commuting is 180ish, 1150's are heavy. 1000 yds is alot. my "learning experience" was only about 100 yards. :)
Posted: Mon Oct 27, 2014 11:56 am
by riceburner
Don't forget you've got a couple of litres in the left side of the tank.
If you're happy that you can pick up your own bike (you should be!), then all you need to do is lay it down gently on it's RHS cylinder head (put something on the floor if you don't want to scratch the head) then pull the bike over a bit further so that the wheels get above 'horizontal'. Then gently rotate the wheels back onto the ground and left the bike up again slowly. You've now got another mile or 3 of gas. ;)
Posted: Tue Oct 28, 2014 7:14 am
by Cohiba54
You're a funny boy "riceburner" thanks for the contribution. I'll have to check that reserve tank out right after i check the water level in the radiator.
Posted: Tue Oct 28, 2014 9:36 am
by riceburner
Cohiba54 wrote:You're a funny boy "riceburner" thanks for the contribution. I'll have to check that reserve tank out right after i check the water level in the radiator.
What? I've done it, it works.
:smt102
Posted: Tue Oct 28, 2014 10:26 am
by peels
:smt102
:D =D>
"the more you know" :lol:
Posted: Tue Oct 28, 2014 11:26 am
by towerworker
I'm glad someone has been paying attention! :lol: :lol:
Posted: Tue Oct 28, 2014 8:09 pm
by Dr. Strangelove
Riceburner is right, sometimes you can access it by shaking/sloshing the bike side to side. That's an old trick.
And what computer? There is not a computer in there, just a on off float. nothing graduated about it. I think the only thing the float does is turn on the low fuel light.
It's a very simple design that works well in my expereince
Posted: Fri Nov 07, 2014 7:31 pm
by carl1957
Was in my fuel tank to do the filter, and found no float/lever fuel sensor. The bike is an '03. Was there an alternative to the float and lever?
Posted: Fri Nov 07, 2014 10:54 pm
by sstein
My 02 does not have a lever. It has what looks like an old-fashioned film canister with a couple of wires connected to it. I don't know if the 03 used the same type of device. 0Maybe yours was pulled out somewhere along the way? Got pics of inside the tank? Are you going to externalizethe filter?
Posted: Sat Nov 08, 2014 11:03 am
by carl1957
I have externalized the filter. I put it in the space in front of the battery. Haven't figured how to post pics here, didn't take any inside the tank. I don't think the fuel sensor was removed, the yellow light comes on at about 140 miles.
Posted: Sat Nov 08, 2014 10:34 pm
by sstein
This is me holding the fuel sending unit. In the photo I have removed the cover exposing the internal float.
https://www.flickr.com/photos/85219855@N04/12870400023/
Posted: Sun Nov 09, 2014 6:37 am
by carl1957
Odd, I click on the link, nothing happens....
Posted: Mon Nov 10, 2014 7:27 am
by sstein
If you right click on it you should get an option to see the pic.
Posted: Mon Nov 10, 2014 1:40 pm
by carl1957
sstein wrote:If you right click on it you should get an option to see the pic.
My Mac laptop does not have that option.
Posted: Tue Nov 11, 2014 9:48 pm
by sstein
Sorry. I'm not too good at posting pics. The unit is a small plastic cylindrical canister about 2 inches long and 1 inch diameter. Has a cap that when removed reveals a circular float.
Posted: Wed Nov 12, 2014 1:31 pm
by carl1957
Thanks, that's probably what I have. Wonder why there's no mention of it in the manual.
