How do you cope without centerstand?
Posted: Sun Jun 01, 2014 3:24 pm
Hi All,
I'm thinking (very vaguely, will likely not happen) of adding an R nineT to the the stable and thought about the fact that the lack of the centerstand might drive me nuts. It's not as bad as on bikes with a chain, but still ...
In my experience with the boxers, if you leave it sitting on the side stand for extended periods of time, oil will run into the lower side cylinder head and burn with some smoke when starting. Is that still the case? Do you use a different stand when in the garage? Just don't care when on the road, but for "storage" prop it up somehow? Or does it just not create the issues I have seen with older ones?
