Page 1 of 2
Rear Drive and Tranmission Oil
Posted: Fri Aug 26, 2005 11:33 pm
by Ed K
Hey Guys,
Sorry if this is a re-tread (and boring topic)...but what's the general consensus on interval for changing rear drive and transmission oil?
Manual indicates 12K miles as I recall for both, but it that sufficient?
Also...any particular recommended synthetic brands?
(I've got a bit over 6K miles on mine now.)
Thanks,
Posted: Fri Aug 26, 2005 11:58 pm
by Lance1150
Are you doubting your manual? Yes, you are. The "Manual" is the result of thousands of hours of testing and calculations by dozens of engineers. I imagine you're smarter than them eh? Well, I bet you aren't.
I'd suggest you follow that manual and have a little faith in German engineering, I know I do.
8)
For those of you offended by the above uppity attitude, I was only doing my best to play the devil's advocate position for the dozens of German engineers who can't be here.
:shock:
Posted: Sat Aug 27, 2005 12:12 am
by BMRBIKR
......Redline Synthetic...... :D
..... but like Lance says......NOT until 12,000 miles!... :smt045
Posted: Sat Aug 27, 2005 8:35 am
by baltm604
unfortunatley, manuals are not edited or published by the engineers. Once marketing and upper management gets involved things change.
If the engineers were the final word why is so much time spent on boards like this one, with everyone from owners to mechanics to manufactures offering creative and time proven solutions not found in the owners manual (an abbreviated version of the cliff notes of a marginally useful service manual).
The same engineers that know everything must think surging is a feature...
"believe half of what you see and none of what you hear"
-Lou Reed
Posted: Sat Aug 27, 2005 8:56 am
by tor1150r
Looking at my maintenance booklet it indicates the following:
Gearbox oil change - 20k kms or every 2 years
Rear drive oil: 1st at the 1000km inspection, then every 40k kms or 2 years
I suggest downloading the maintenance schedule from BMW's web site as this may be updated more often than the printed booklet.
tor1150r
Posted: Sat Aug 27, 2005 9:42 am
by Deans BMW
BMW 70/140 Synth in the tranny and Mobil 1 70/90 synth in the rear drive. I usually change both every year regardless of milage.
Lube changes...
Posted: Sat Aug 27, 2005 2:12 pm
by dallara
I dunno'...
It's weird, but there is something that just gives you a *good* feeling knowing you have fresh lubes in all the right places, and that they are topped up to spec. Probably nothing to it, but having fresh lubes can't hurt...
Sooooooooo, I probably tend to change my various oils more often than necessary, but then I have never had any sort of lubrication related failure. Maybe it comes from racing bikes and cars so long, where we changed lubes all the time.
I change out my engine oil every 3,000 to 4,000 miles.
Change the gearbox and final drive every 6,000 to 8,000 miles.
Like Dean, if I have a bike that hasn't had that kind of mileage in a year I change 'em all out regardless of mileage... condensation and all that possible contamination over the year doing what it can do, etc.
Really, when you get right down to it, fresh oil for engine, gearbox, and the final drive is *CHEAP*, and cheap insurance, too. It seems odd to me that someone would spend $10,000 on a motorcycle and then try to economize over the $30-$40 bucks or so it takes for swapping all the lubes to fresh two or three times a year...
Just my $0.02... YMMV, of course.
Cheers!
Dallara
Posted: Sat Aug 27, 2005 3:51 pm
by Paper
Edited, and moved on...
Posted: Sat Aug 27, 2005 4:10 pm
by darthrider
but I've found that a cut out and rolled up lenthwise section of beer can, slid into the drain area, keeps MOST of the oil off the cat when draining it.
Geeze, maybe I can find an empty beer can at one of my buddy's houses...
Can you use...
Posted: Sat Aug 27, 2005 4:22 pm
by dallara
Can you use an empty scotch bottle?
:lol: :wink: :lol: :wink: :lol:
Cheers!
Dallara
Posted: Sat Aug 27, 2005 4:27 pm
by Biff's R
Can you use...
Only if you can roll it up. :D
Posted: Sat Aug 27, 2005 8:29 pm
by Ed K
I was thinking along the lines of Dean...Dallara...6-8K miles or 1 year, whichever is sooner rule...cheap insurance.
I have always changed engine oil every 3K miles for all vehicles I have owned, regardless of manufacturer's recommendation.
And now I am adding 1/2 bottle of Techron at the end of each 3K engine oil change cycle, to avoid carbon build-up. (I run a full tank with the Techron down to reserve just before oil change, to ensure any Techron blow-by that might have occurred, is removed with the engine oil change.)
Tranny and rear end changes, however, varies on my vehicles.
I like the 6-8K mile or 1 year rule...no offense to those who chose other options...but I am reassured of my inclination by the experience of Dean and Dallara.
By the way, Dean, why do you use BMW in tranny and Mobil in rear? Why not BMW or Mobil in both...is it that Mobil does not make the viscocity required for the tranny?
Dallara, what synth to you use?
Others? What is your choice for tranny and rear end juice?
I have used Redline in the past on vehicle transmissions under great stress (a souped-up RX-7 with a large after market turbo that I installed), with great success...but still a little unsure of making that leap to the bike.
Tranny/rear end lube
Posted: Sat Aug 27, 2005 9:10 pm
by Xray28
BMW 75/140 changed at 12K since I'm doing a lot fo stuff and have my torque wrenches out at that time anyway.
well, Ed K...
Posted: Sat Aug 27, 2005 9:28 pm
by dallara
Well, Ed K...
I am a bit of an Amsoil queer... But not because I am a "Believer" in Amsoil so much, but because I signed up for their "Preferred Customer Discount" deal...
I am a *BIG* believer in synthetic oils, period, That comes from experience in both motorcycle and car racing. To me, any good quality synthetic is light-years past a good dino oil (except during break- or run-in...).
I use Amsoil 140/90 in the gearbox, and Amsoil 75/90 in the rear end.
Hope this helps!
Cheers!
Dallara
Posted: Sun Aug 28, 2005 9:42 am
by Deans BMW
Where I live, Amzoil or Redline is not avaliable and Mobil 1 is every where. Mobil 1 does noe have a 70/140 synth that I know of. Also Chris at San Jose BMW speaks highly of Mobil 1.
changing oils
Posted: Sun Aug 28, 2005 12:41 pm
by bakernks
Friend of mine once told me a theory that I've held to since the 80's. "I can afford a case of oil. I can't afford another engine."
I change engine oil and filter every 3,000 miles.
I change transmission lube and rear end lube every 6,000 miles.
My 1990 GMC 350 V-8 has gotten the same schedual since I bought it new. It does use 1 pint oil now between 3,000 change intervals, at 140,000 miles.
Amen, Brother... Amen...
Posted: Sun Aug 28, 2005 1:07 pm
by dallara
Amen, Brother... Amen!
Cheers!
Dallara
Transmision and Final Drive oil change
Posted: Wed Aug 23, 2006 8:18 pm
by crousos
Can someone please point me to some instructions on how to do that and oil cappacity for both transmision and final drive.
Tinos
Trans Oil Change
Posted: Wed Aug 23, 2006 8:26 pm
by MikeCam
Hmmmm! From memory....
on right side midships is the transmission filler and drain plugs. Upper is filler plug (8mm Hex bit socket) and lower is drain (duh!).
Bike on centerstand. Remove filler plug. Remove drain plug. Drain tranny fluid into suitable container. Smell that good smell of clean unburned tranny fluid. Smells burned? Worth checking with dealer/service tech for cause. Carefully tilt bike to insure most fluid drains....might want a helper. Inspect plug head for any residual bright metal bits. BAD. Small non-shiney,crud residue -OK.
Replace plug. Torque 22-23 foot pounds 30Nm. Wrist tight plus 1/16 turn.
Replace tranny fluid with your choice of natural or synthetic (better regardless of mileage I think) API GL5 in 80W90, 75W140, or Redline HD Shockproof (the good stuff!). Add a measured 0.80 liter (.85 quart) to bottom of filler threads. Replace filler plug. Torque 22-23 fp/30Nm.
HTH
Ahhhhh! Pages 73 and 79 in Maintenance manual.
Re: Transmision and Final Drive oil change
Posted: Wed Aug 23, 2006 8:27 pm
by NHighCotton
crousos wrote:Can someone please point me to some instructions on how to do that and oil cappacity for both transmision and final drive.
Tinos
http://www.trickery.cz/manualy/bmw/bmw% ... %20eng.pdf
