JW Speaker LED Light
Posted: Mon Nov 18, 2013 9:33 pm
by Soliton
I bought and fitted a JW Speaker Evolution 8700 headlight. Experiences as follows.
The light is beautifully made and when installed it casts an even, bright white light with a flat cutoff. The electricals are a straight h4 swap. I am in Australia and although we have right hand traffic I used the US version. The beam pattern is the same. The difference in the RHT version is the ECE stamp and the option of a parking light (which I didn't use on the incandescent so i haven't missed it.) The other big difference is the price. The LHT version is about half the cost. (US$390)
The basic light will not fit inside the standard shell. It is about 18mm to small. I tried to make an adaptor ring but eventually bit the bullet and bought the JW speaker 7" headlight shell (US$ 67). The shell is everything the light isn't. It's cheap and nasty. My main concerns were:
  • There are no assembly instructions and after 3/4 of an hour or so I worked out that you had to disassemble it to assemble it.
    The trim ring was scratched when I got it
    The paint was poorly applied, the inside still had primer showing
    The outside edge of the shell has no knurling to prevent is rotating
    The shell has no weather proofing at all and would be very difficult to weather proof. This means that all of the internal connections themselves have to be weather proofed.
    No grommets are supplied for the rear of the shell in the spot where the cables pass through.
    The shell is small, this means that if you have a relay (which may have been seated in the existing shell) you will have difficulty.
To offset the shell problems I sprayed all of the parts with black rubberised truck bed paint (corrosion and scratch protection) and I have disconnected the relay for the moment. The light itself pulls a much lower current. I made a grommett with two pieces of "peel and stick" closed cell foam stuck back to back. Next step will be to be more heavily weatherproof the internal connectors. Since the shell is smaller you will need to put spacers on the outside of it when it is bolted back into place. I used rubber spacers to help to prevent it rotating, and the insertion of spacers may add the need for slightly longer bolts.
I also dropped the mounting of the light by 70mm and moved it forward by 40mm. This is not a requirement but it offsets the prairie dog look of the original mount point. This did require making extra mounting brackets (double thickness 3mm black kydex although I may make stainless ones and moving the screen but I like the look a lot better. I moved the screen by re-drilling the mounting holes and then filling the old holes, (sand polish and paint). I also put some black rubber spacers between the mount and the back of the screen. My screen is painted black to match the bike, this would be more of a problem if you wanted to maintain the clear screen.
So...The light is much better than the original, the electrical swap is easy but the JW Speaker bucket is poorly made. My feeling is that the company has sourced them externally. It wasn't a cheap job but where I live kangaroos are a very real hazard and if you hit one on a bike it is ALL bad, so good lighting is something I am happy to pay for. That said I will probably still put on some small secondary LED spots.
Verdict
Happy with the light but the mounting shell is no where near the quality of the build of the light. The whole job including custom mounts was about a days work. if you don't move the light it would be MUCH quicker.
Regards,
Sol
Re: JW Speaker LED Light
Posted: Wed Feb 15, 2017 1:21 pm
by edbikerii
Thank you for posting this review. Any update on this now after 3 years?
Posted: Wed Feb 15, 2017 3:26 pm
by EasyBee
Yes, interested. Any pictures? I'm thinking about the adaptive version, the 8790 adaptive
http://www.jwspeaker.com/products/adapt ... -adaptive/
https://www.youtube-nocookie.com/embed/ ... showinfo=0
They're also sold in the Netherlands, there's a dealer just around the corner from my place :D
Posted: Wed Feb 15, 2017 6:46 pm
by edbikerii
Wow! Cool video! Looks like a great idea, but I'd be afraid to buy it without real-world, unbiased, feedback. It seems like it could be a little "gimmicky".
Posted: Wed Feb 15, 2017 6:49 pm
by edbikerii
Oh, then there's the $799 price. Hmm.... Cheaper than physical therapy after a crash... What else can I rationalize this with?
Posted: Thu Feb 16, 2017 5:23 pm
by EasyBee
Yep, they are expensive, Here's a "review"
Posted: Sun Feb 19, 2017 8:29 am
by EasyBee
edbikerii wrote:Oh, then there's the $799 price. Hmm.... Cheaper than physical therapy after a crash... What else can I rationalize this with?
How about a totally different price tag of $ 99.99 ? On AliExpress I found this adaptive verion
https://nl.aliexpress.com/item/94-13-HA ... Title=true.
Posted: Thu Mar 16, 2017 9:49 am
by edbikerii
Interesting. I've had mixed luck with AliExpress, though. Sometimes cheap imitations. Did you try it?
Posted: Thu Mar 16, 2017 2:25 pm
by EasyBee
Yep, I bought the Aliexpress version and about a week later it arrived. But ofcourse it doesn't fit in the standard bucket with the standard chrome rim. So you have to find something to make it fit. I found a video from a guy with a Ducati Monster 620. That 7 inch headlight looks a lot like an R1150R. :D
https://www.youtube.com/watch?v=-GmmZw9Kc9U . But that's a complete kit from Motodemic, headlight with an adaptive ring.
That adapter is also on the website of J.W. Speaker. http://www.jwspeaker.com/products/motor ... 0/0703401/
Next step, contact Brad Wood at Motodemic and ask the if they sell the adaptive ring separately. Yep, they do
https://motodemic.com/shop/ducati-7-inc ... pter-ring/
(so new, they don't have a picture and you actually can't find it on their website, and they don't even mention BMW, only Ducati).
Ordered it and within a week my adapter arrived.
The AliExpress headlight fits perfectly in de Motodemic adapter for the J.W. Speaker adaptive 8790. It fits like a glove, really tight :biggrin:
Oh, before I forget. When you turn it on, it does that same initialisation dance like in the video.
