signal minder only half minding
Posted: Tue Nov 05, 2013 8:56 pm
by zeke
I noticed today that my signal minder seems to only work for right turns. Self canceling feature works properly for right turns, but not for left. Is this a sign of early failure? The running light feature still work properly, as does the flashing brake feature. Thoughts? Will giggling the wires in the box help to solve this or is it more serious? Thanks
Re: signal minder only half minding
Posted: Tue Nov 05, 2013 11:09 pm
by towerworker
I have a Signal Minder as well. I've never had an issue. (yet)! I've not heard of a problem like yours. Makes me think it's not sensing your left turn switch. I would think it's possibly an issue of a dirty or poor electrical connection. I would disconnect the device and simply reconnect it. Just disconnecting and re-connecting tends to partially clean connections. A good practice is to use a little dab of conductive dielectric grease on electrical connections. It tends to help keep connections free of dirt and water and helps conductivity within dissimilar metals. For safety's sake I'd recommend disconnecting your battery before doing a lot of electrical troubleshooting. I know getting to the battery leads is often a real PITA but it's a real wise move unless you're very certain of what wires you may be messing with.
Posted: Wed Nov 06, 2013 12:11 am
by Frank1150r
I've had my signal minder for 12 years without an issue, I'm guessing here, have you checked the front and rear signal bulbs?
Frank
Posted: Wed Nov 06, 2013 9:20 pm
by fpgirard
no problems here with my signal minder...... is possible to switch left and right to see if the problem follows wiring or stays with SM?
Posted: Wed Nov 20, 2013 7:44 pm
by zeke
Finally did a bit more research on this while I was doing an oil change. Got out a stop watch and the instruction manual. I must have done something that altered the settings as the sm worked like it should, though 45 seconds is a long time when you are waiting for a flashing light to stop. I adjusted the settings several times and each worked properly. Guess I did something wierd or bumped something that caused me to think the signals were not activating properly. If oddities continue I'll post again.
Posted: Thu Nov 21, 2013 1:35 am
by sweatmark
FWIW, "Signal Minder weakness":
http://www.advrider.com/forums/showthread.php?t=38271
Was reminded of this fix-it reference by original poster's claim that one side wasn't working.
Posted: Thu Nov 21, 2013 7:01 pm
by zeke
Man, just when I thought I was out...I get pulled back in. Appreciate the link, will certainly keep an eye on the turn signals to see if they act up over the next few weeks. Oh and just to heap on to the todo list...the right front turn signal went out today.
All joking aside. I do very much appreciate the insight and assistance. Thanks!
