R1200R Classic and Michelin PR3's with tubes
arp
Donating Member #: 1124
Post by arp »
After two sets of Metzler Roadtec Z8 tires (perfectly happy with them btw, 8-10k mi no problem) I decided to try the Michelin PR3 tires. These tires are not on the BMW list of tire options for the R1200R Classic and the Michelin Fitment Guide prohibits the use of inner tubes with the PR3 tires. Does anyone have any experience running PR3 tires with tubes on the Classic? It seems like heat/chafing on the tube might be an issue. Hope I have not made a mistake.
Alex
'17 R1200GSA, 3k mi
'14 R1200RT, 27k mi
'12 R1200R Classic, 42k mi (traded)
David R
Re: R1200R Classic and Michelin PR3's with tubes
Post by David R »
Michelin tires are not a mistake.
For the tubes, I can't comment I have cast wheels.
David
mogu83
Post by mogu83 »
No specific experience. I've run tubes in Metzler ME33 and ME99 tires (now Lazertec) on my airhead for many years without any ill effects. However the old bike comes up a little short in performance and power compared to the new bikes. I was always told the big problem with running tubes in tubeless tires was heat build up, but that was back in the bias tire days.
Looks like your going to have to make a gut call on this one.
cgl
Post by cgl »
I had the PR3 on my Classic for over a year and 10 k km since day one. Longest distance road was 200 km. Did a few track sessions too. No issues so far.
92 Suzuki GN125
95 Suzuki Intruder 400
00 R1100R
06 HD Sportster 1200
08 F800ST
11 R1200R Classic
mogu83
Post by mogu83 »
Looks like time to install a tire pressure and temperature monitoring system. Highest I've seem my rear tire was 130 degrees while running the slabs out West, ambient temp around 100 +/-.
Karamazov
Donating Member #: 540
Post by Karamazov »
I don't use PR3s myself, but I don't see why they would be any different than the other tubeless type tires that are being used with tubes on the Classic. If I had to guess, I'd say the only reason it's not on the BMW recommended list, is because it was introduced after the list was published.
N8
- '14 Dark White
- '14 R NineT
- '12 R1200R Classic
- '07 R1200R (Caged)
arp
Post by arp »
Even the OEM installed configuration violates a couple of Metzler's restrictions given on their website. The vehicle and tire manufactures seem to point the finger at one another when it comes to responsibility.
It is good to know others are using the PR3s on the Classic with no problems. Thanks.
Alex
'17 R1200GSA, 3k mi
'14 R1200RT, 27k mi
SF_Hooligan
Post by SF_Hooligan »
I'm on my second set of PR3s on my Classic. Love 'em, no issues.
