fuel line quick connect
possum
Donating Member #: 751
Post by possum »
Sorry, if this has been talked about many times I am sure.... one of my quick connects is pouring fuel.... I have disconnected and re connected many times now, in hopes for a better connection... no luck... Do I need to replace or is there a trick that I am over looking?... Thanks for your time.
Lookin for a place to happen,making stops along the way.
slowtorque
Re: fuel line quick connect
Post by slowtorque »
No worries. If you have the stock plastic units, the male fitting is commonly easily broken. If your o-ring is intact and not missing or torn, look it over carefully for cracks. Make sure it clicks together properly when connecting. I upgraded to the metal units offered by Beemershop before the nearly inevitable failure of the plastic ones.
Johnny
04 R1150R GONE
10 R1200R GONE
possum
Post by possum »
I checked over... nothing is cracked or broken .. I even put a new o-ring on... that didn't help at all :smt010 .. I am guessing the quick connections were made in ... well not germany
possum
Post by possum »
Are only the male fittings needed ?
slowtorque
It is my understanding that the male part is the problem, but they are generally sold in pairs and that is what I did.
Johnny
04 R1150R GONE
10 R1200R GONE
slowtorque
Got mine from Mike at Beemerboneyard:
http://www.beemerboneyard.com/cpcqkdiscon.html
Likely available elsewhere.
Johnny
04 R1150R GONE
10 R1200R GONE
possum
Post by possum »
Thanks slowtorque;
Buckster
Donating Member #: 543
Post by Buckster »
I would just replace them. It is not worth the agony of having one go on you while you are on the road. I'm not sure if the was a recall on those from BMW, but last year when I was having my state inspection, the shop manager asked if I had the QD's replaced yet. I had done them years ago with the Omega's.
Buckster '03R
#543
possum
Post by possum »
Could I just put a regular brass fitting to make the connection?.... or does the fitting need to be vavled?
AndyRR
Post by AndyRR »
You can run with just a plain brass fitting. The valves are't check-valves and are only closed when the lines are disconnected. It'll just be a PITA late on if/when you have to pull the tank. I ran into a similar issue and decided that I would go ahead and replace all the rubber fuel lines. I ran with no fittings at all until I got around to ordering and installing the beamerboneyard set. Be sure to use Fuel injection clamps and not the standard hose clamps.
possum
Post by possum »
just out of curiosity sake.... does anyone have any experience with the Jiffy-tite quick connects...
