Clutch & brake lever replacement
Posted: Mon Aug 08, 2011 11:10 am
Hi, folks,
What might be a dumb question here...
When I went to try to replace my '08 R1200R's brake and clutch levers, I found I couldn't remove the pivot-and-plunger assembly from the old lever. The pivot and plunger need to be reused on the new lever, but the piece they ride in, does not. It looks like the plunger should unthread from the pivot, letting both be removed from the assembly, but I can't find a hex-hey that both fits and doesn't spin in the back of the plunger and I'm a tad reluctant to mash down on the plunger with a Vice-grips.
More frustratingly, when I check the service manual, the pivot-and-plunger assembly is clearly there; but neither the individual parts nor the assembly appear to be on the BMW parts fiche for the bike (e.g. http://www.ascycles.com/Illustrated_cat ... 2+Steering).
At this point I'd rather order new parts than risk messing up my old levers, but how can I do that if I can't find the parts to order? Thoughts? (The quasi-local dealer just went out of business; the next nearest dealer is ~100 miles away.)
Thanks much,
- Lewellen180
Thanks much,
- Lewellen180
