R1150R - Wunderlich Rear cowl fitted
Posted: Fri Jun 25, 2010 9:02 am
by allanj255
Here are a few more mods done to my 2003 1150R.
Wunderlich cowl - replaces rear section of seat. Had a few problems mounting it as bracket supplied was to long and holes drilled in the wrong place on the cowl base. Wunderlich very unhelpful so I had to cut and redrill it myself after lots of measuring.
Also Wunderlich rear wheel hub centre fitted & Remus carbon end can & Y pipe
Carbon fibre oil cooler covers and rear hugger
Re: R1150R Real cowl
Posted: Fri Jun 25, 2010 9:44 am
by boxermania
Very nice, makes for a good looking bike....cheers
Re: R1150R - Wunderlich Rear cowl fitted
Posted: Sat Jun 26, 2010 9:23 pm
by bikermeow
I've always been curious about the under-the-cowl storage compartment that wunderlich boasts. Mind showing a close up of that?
Cheers
Posted: Sun Jun 27, 2010 6:37 am
by allanj255
Will take a picture, there is a small hatch in the base of the cowl secured by 2 screws but all I keep in it is the puncture kit well wrapped up in bubble rap and a pair of waterproof trousers as anything loose would move around and if heavy could crack/damage the cowl. It is well made of Fiberglass - you could not get the standard BMW tool roll through the or if you did it would be a tight fit.
Posted: Sun Jun 27, 2010 6:47 am
by allanj255
bikermeow wrote:I've always been curious about the under-the-cowl storage compartment that wunderlich boasts. Mind showing a close up of that?
Cheers
As requested - carbon fibre hatch secured with 2 screws., I have had to shorten the mounting arm and move it back as Wunderlich supplied it too long and drilled in wrong place - very poor customer service - had to work it out myself by measuring original seat but dimensions were different so did a few trial fittings before cutting and drilling.(this is before I cut it and moved mounting towards front of bike) But despite this I am happy with the look
Next to original seat
Posted: Sun Jun 27, 2010 2:29 pm
by AirForceDirt
As I recall, those cowls are an awful lot of money for it not to fit on the first go. How do they justify the poor fit?
I was honestly looking into getting one of those, but if they have to be modified to fit, and customer service is that crappy, I might have one custom fabricated.
Posted: Sun Jun 27, 2010 7:21 pm
by Xdot
Sweeet.
I was actually thinking of fabricating a rear cowl from wood. Don't laugh, it is the original layered, fiber material. It is strong, lightweight, and properly finished, looks identical to fiberglass and is completely weatherproof.
Posted: Mon Jun 28, 2010 7:31 am
by AirForceDirt
Xdot wrote:Sweeet.
Sure, if you can layer it properly, then weather seal it and keep it from getting wet or from cracking in the heat. Fiberglass is quite a bit easier to work with, lighter, and more weatherproof than wood.
Posted: Mon Jun 28, 2010 9:19 pm
by Xdot
Not set up for glass but I'm an expert with wood. Always wanted to try glass though.
